Learn how to automate content translation using AI Agent with Pabbly Connect, integrating Google Sheets, OpenAI, and WordPress seamlessly. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To start automating content translation using AI Agent, the first step is to access Pabbly Connect. Visit the Pabbly website by typing Pabbly.com/connect in your browser.
Once on the site, you will need to sign in to your Pabbly account. Click on the ‘Sign In’ button if you are an existing user, or ‘Sign Up for Free’ if you are new. Signing up gives you access to 100 free tasks monthly, allowing you to explore the features of Pabbly Connect.
After logging in, navigate to the Pabbly Connect dashboard to create a new workflow. Click on the ‘Create Workflow’ button, and provide a name for your workflow, such as ‘How to Automate Content Translation Using AI Agent’. using Pabbly Connect
  • Select the folder where you want to save the workflow.
  • Click on ‘Create’ to finalize the setup.
This action will set up the trigger and action boxes in your workflow. The trigger indicates when the automation starts, and the action specifies what happens next. In this case, the trigger is when new content is added to Google Sheets.
In this step, you will set Google Sheets as the trigger application. Select Google Sheets and choose the trigger event as ‘New or Updated Spreadsheet Row’. This setup allows Pabbly Connect to monitor your Google Sheets for new content.
You will be provided with a webhook URL that acts as a bridge between Google Sheets and Pabbly Connect. Open your Google Sheets, navigate to Extensions, select Add-ons, and then Get Add-ons to install the Pabbly Connect Webhooks add-on if you haven’t done so already.
  • Paste the webhook URL into the setup box in Google Sheets.
  • Set the trigger column as the final data entry column, typically column C.
After completing the setup, send a test from Google Sheets to ensure that the data is successfully sent to Pabbly Connect. This establishes a connection that will allow the automation to function correctly.
4. Using OpenAI for Content Translation
Once the connection is established, the next step is to integrate OpenAI as an action within Pabbly Connect. Choose OpenAI and select the action event as ‘Chat GPT’ for generating translations.
To connect OpenAI, you will need an API token. Click on the link provided to create a new API key from the OpenAI dashboard. Once you have the token, input it into Pabbly Connect to establish the connection.
Select the AI model you want to use for translation, like GPT-4 mini. Create a prompt that instructs OpenAI on how to translate the content.
Using mapping, ensure that the title, content, and language are dynamically included in your prompt. This allows Pabbly Connect to send the correct data for translation every time new content is added.
5. Posting Translated Content to WordPress
After receiving the translated content from OpenAI, the final step is to post it to WordPress using Pabbly Connect. Add a new action step and select WordPress, choosing ‘Create a Post’ as the action event.
To connect WordPress, enter your site’s base URL and login credentials. Once connected, fill in the required fields such as post type, title, and content with the translated information received from OpenAI.
Set the post status to publish or draft as per your preference. Map the translated title and content from the OpenAI response.
Finally, click on ‘Save and Send Test Request’ to create the post on your WordPress site. Refresh your WordPress dashboard to see the new post with the translated content created by Pabbly Connect.
In this tutorial, you learned how to automate content translation using AI Agent with Pabbly Connect. By integrating Google Sheets, OpenAI, and WordPress, you can streamline your content creation process effectively.
