Learn how to automate sending brochures via WhatsApp for LinkedIn leads using Pabbly Connect. Step-by-step guide for seamless integration. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To begin automating the process of sending brochures via WhatsApp for LinkedIn leads, you need to access Pabbly Connect. Visit the official Pabbly website and navigate to the Pabbly Connect section. If you are a new user, you can sign up for free and explore the features of Pabbly Connect with 100 free tasks every month.
Existing users can simply log in to their accounts. Once logged in, you will see the dashboard where all applications are listed. Click on the ‘Access Now’ button under the Pabbly Connect section to start creating your automation workflow.
After accessing Pabbly Connect, click on the ‘Create Workflow’ button located at the top right corner. You will be prompted to name your workflow. For this tutorial, name it ‘Auto Send Brochure via WhatsApp for LinkedIn Leads’. Choose a suitable folder for your workflow and click the ‘Create’ button.
- Select a folder to organize your workflows.
- Click on the ‘Create’ button to finalize.
Your workflow is now created, and you will need to set up the trigger. In Pabbly Connect, triggers are the events that start your automation.
3. Setting Up the Trigger for LinkedIn Lead Ads
In this step, you need to set up the trigger that will initiate the workflow when a new lead is generated from LinkedIn. Select ‘LinkedIn Lead Ads’ as your trigger application. The event you want to capture is ‘Lead Notification’. Click the ‘Connect’ button to establish a connection. using Pabbly Connect
You can choose to add a new connection by clicking on the ‘Connect with LinkedIn’ button. Enter your LinkedIn account password when prompted and confirm the connection. After successfully connecting, select your sponsored account from the dropdown menu and click on the ‘Save and Send Test Request’ button to test the trigger.
4. Sending WhatsApp Messages via Pabbly Connect
Once the trigger is set up, the next step is to send a WhatsApp message using the WhatsApp Cloud API. In your workflow, add an action step by selecting ‘WhatsApp Cloud API’ as the action application. Choose the event ‘Send Template Message’ and click the ‘Connect’ button. using Pabbly Connect
- Fill in the required fields such as token, phone number ID, and WhatsApp business account ID.
- Map the phone number field to the lead’s phone number captured from the trigger.
- Select the template you created for the WhatsApp message.
Ensure to include the media link for the brochure uploaded to your WordPress account. Once all fields are filled and data is mapped correctly, click on the ‘Save and Send Test Request’ button to send a test message.
5. Conclusion: Automate Your Leads with Pabbly Connect
In this tutorial, you learned how to automate the process of sending brochures via WhatsApp for LinkedIn leads using Pabbly Connect. By following the steps outlined, you can create a seamless workflow that enhances your lead engagement.
Utilizing Pabbly Connect not only simplifies this process but also allows you to integrate various applications effectively, ensuring that your marketing efforts are both efficient and effective. Start automating today with Pabbly Connect and watch your lead conversion rates increase.
