Learn how to use Pabbly Connect to auto-publish your Instagram posts to multiple social media platforms like Facebook, Twitter, and LinkedIn seamlessly. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To begin the process of auto-publishing your Instagram posts to multiple social media platforms, you need to access Pabbly Connect. Start by typing the URL Pabbly.com/connect in your browser. Once on the landing page, you will see options for signing in or signing up.
If you are a new user, click on the ‘Sign Up for Free’ button to create an account. This process takes less than two minutes, and you will receive 100 free tasks upon account creation. Existing users should simply sign in to access their dashboard.
Once you are signed into Pabbly Connect, navigate to the dashboard and click on the ‘Create Workflow’ button. A prompt will appear asking you to name your workflow. Here, you can name it something like ‘Auto Publish Instagram Posts to Multiple Social Media Platforms’ and then click on ‘Create’.
In this new window, you will encounter two key sections: ‘Trigger’ and ‘Action’. The trigger application you will select is ‘Instagram for Business’, and the trigger event will be ‘New Media Posted’. This setup means that every time you post on Instagram, this workflow will check for new data every 10 minutes.
- Select ‘Instagram for Business’ as the trigger application.
- Choose ‘New Media Posted’ as the trigger event.
- Connect your Instagram account by clicking ‘Add New Connection’.
After connecting, you will be able to access your Instagram data through Pabbly Connect.
3. Send Instagram Post to Twitter
Next, you will set up the action to post on Twitter. In the action application section, select ‘Twitter’ and choose the action event as ‘Create Tweet with Media’. Again, click on ‘Connect’ to link your Twitter account with Pabbly Connect.
Once the connection is successful, you need to map the information from the previous step. This involves selecting the caption and media URL from your Instagram post. Mapping ensures that the latest data is used every time a post is made.
- Map the caption from Instagram to the Twitter tweet.
- Map the media URL to attach the image.
- Click on ‘Save and Send Test Request’ to test the connection.
After testing, you should see the tweet appear on your Twitter account, confirming that Pabbly Connect has successfully facilitated this integration.
4. Post to Facebook Group Using Pabbly Connect
Now, let’s move on to posting in a Facebook group. In the next action application, select ‘Facebook Groups’ and choose the action event as ‘Post Photo’. Click on ‘Connect’ to link your Facebook group with Pabbly Connect.
After authorization, specify which Facebook group you want to post to. For example, you can choose the ‘Social Circle’ group. You will again need to map the image URL and the caption from the Instagram post to ensure that the correct content is shared.
Select your Facebook group from the list. Map the image URL and caption from the Instagram post. Click on ‘Save and Send Test Request’ to verify the connection.
Once confirmed, your post should appear in the selected Facebook group, showcasing the power of Pabbly Connect in automating your social media tasks.
5. Share Instagram Post on LinkedIn
Finally, let’s set up the integration for LinkedIn. Choose ‘LinkedIn’ as the action application and select the action event as ‘Share an Article or URL’. After connecting your LinkedIn account through Pabbly Connect, you’ll need to fill in the author name, post content, and URL.
Make sure to map the caption and URL from your Instagram post to ensure the content is accurate. After completing the mapping, click on ‘Save and Send Test Request’ to execute the action. This will post your content on LinkedIn, confirming that the integration is complete.
To summarize, the integration setup involves the following applications and events:
Trigger: Instagram for Business – New Media Posted. Action 1: Twitter – Create Tweet with Media. Action 2: Facebook Groups – Post Photo. Action 3: LinkedIn – Share an Article or URL.
This entire process demonstrates the efficiency of using Pabbly Connect to automate social media publishing.
In conclusion, using Pabbly Connect allows you to seamlessly auto-publish your Instagram posts to multiple social media platforms like Twitter, Facebook, and LinkedIn. This integration not only saves time but also enhances your social media presence effortlessly.
