Learn how to use Pabbly Connect to automate the generation of professional LinkedIn posts using AI tools. Step-by-step tutorial for seamless integration. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To start using Pabbly Connect for auto-generating professional posts, first, access the platform by visiting Pabbly Connect at Pabbly.com/connect. Here, you can either sign in or create a free account.
New users can click on the ‘Sign Up Free’ option to explore the software. Existing users should simply log in. Pabbly Connect allows you to automate tasks effectively, making it a powerful tool for your LinkedIn posting strategy.
Once logged into Pabbly Connect, navigate to create a new workflow. Click on the ‘Create Workflow’ button, where you will be prompted to name your workflow. For this tutorial, name it ‘Auto Generate Professional Posts Using AI Agent’.
  • Select your desired folder for organization.
  • Choose between the Beta or Classic version for workflow creation.
After naming your workflow, click on the ‘Create’ button. This sets up the foundation for your automation process using Pabbly Connect.
3. Setting Up the Trigger for Daily Posts
The next step involves setting up a trigger. In Pabbly Connect, triggers initiate the automation process. For this task, select the ‘Schedule’ feature to run your automation daily at a specified time.
Configure the trigger by selecting the frequency (every day) and the specific time (12 PM). Click ‘Save’ to confirm the scheduled trigger. This will ensure your workflow runs at your desired time every day.
4. Generating Content Using AI Tools
After setting the trigger, the next action is to generate content using an AI tool. In your workflow, add an action step and select your AI application, such as Gemini or OpenAI, to generate professional content for LinkedIn posts.
  • Choose the ‘Generate Content’ action from the AI tool.
  • Input the prompt for the AI to generate relevant content.
Once the content is generated, you can proceed to share it on LinkedIn, thus completing the automation process facilitated by Pabbly Connect.
5. Posting Automatically on LinkedIn
The final action in your workflow is to post the generated content on LinkedIn. Add another action step in Pabbly Connect and select LinkedIn as your application.
Choose the action event as ‘Share Simple Text’, and map the generated content from the previous step. After setting up the connection with your LinkedIn account, click ‘Save’ to finalize the posting action. Your automation is now complete!
In this tutorial, we explored how to use Pabbly Connect to automate the generation and posting of professional content on LinkedIn. By following these steps, you can streamline your posting process and maintain consistency effortlessly.
