Learn how to automatically add Mailchimp subscribers from Instamojo sales using Pabbly Connect. Step-by-step guide for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To begin the integration process, you need to access Pabbly Connect. Start by visiting the URL Pabbly.com/connect. This will take you to the landing page of the platform, where you can either sign in or sign up for a new account.
If you are a new user, click on the ‘Sign Up’ button to create an account, which takes less than two minutes. Existing users can simply log in. Upon signing in, you will be directed to the dashboard where you can create workflows.
After logging into Pabbly Connect, click on the ‘Create Workflow’ button. A dialog box will prompt you to name your workflow. For this integration, name it ‘ADD Mailchimp Subscriber When New Sale Happens in Instamojo’ and click ‘Create’.
Next, you will see two main sections: Trigger and Action. The trigger application will be Instamojo, and the event will be ‘New Sale’. This means every time a sale occurs, the workflow will be activated. Copy the provided webhook URL as this will connect Pabbly Connect with Instamojo.
3. Setting Up Instamojo to Trigger Pabbly Connect
Now, go to your Instamojo account and navigate to the Smart Pages section. Select the product you want to sell and click on the three dots to edit the page. In the page settings, paste the webhook URL you copied from Pabbly Connect into the appropriate field.
After saving your changes, go back to Pabbly Connect and perform a test submission to ensure the connection is successful. Open the payment page in an incognito window, fill in the necessary details, and complete a payment. Once the payment is processed, Pabbly Connect will receive the API response containing the sale details.
- Go to Instamojo and select your product.
- Edit the page settings to include the webhook URL.
- Perform a test payment to trigger the webhook.
Once the payment is successful, check Pabbly Connect for the received data, which includes payment status, user details, and more.
4. Adding Mailchimp Subscriber via Pabbly Connect
With the data received from the payment, the next step is to add a subscriber to Mailchimp. In Pabbly Connect, click to add another action step and select Mailchimp as the application. Choose the action event as ‘Add New Member with Custom Fields’.
You will need to connect your Mailchimp account by providing an API key and data center information. Retrieve your API key from your Mailchimp account settings under the profile section. Copy this key and paste it into Pabbly Connect. The data center is the subdomain part of your Mailchimp URL, which you will also need to enter.
- Select Mailchimp as the action application.
- Provide the API key and data center.
- Map the email address and other fields for the new subscriber.
After mapping the fields, such as email address and name, click ‘Save and Send Test Request’ to check if the subscriber is added successfully to Mailchimp.
5. Testing the Complete Integration
To ensure everything is working as expected, perform a real-time test. Go back to Instamojo and create another payment using a different set of user details. Once the payment is completed, check your Mailchimp account to see if the new subscriber has been added.
Refresh the Mailchimp contacts page, and if the new subscriber appears, it confirms that the integration via Pabbly Connect is successful. This process illustrates how easily you can automate subscriber additions based on sales made through Instamojo.
In this tutorial, we explored how to use Pabbly Connect to automatically add Mailchimp subscribers from Instamojo sales. By following the outlined steps, you can streamline your email marketing efforts and enhance your customer engagement.
