Learn how to automate adding Typeform entries as subscribers in MailerLite using Pabbly Connect with this step-by-step tutorial. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
1. Setting Up Pabbly Connect for Typeform and MailerLite Integration
To begin automating the process of adding Typeform entries as subscribers in MailerLite, you need to access Pabbly Connect. First, create a free account or log in if you are an existing user.
Once logged in, click on the blue button labeled ‘Create Workflow’. Name your workflow, for example, ‘When Form is Submitted in Typeform, Create Subscriber in MailerLite’. This sets the stage for your automation process.
2. Configuring the Trigger Event in Pabbly Connect
In this step, you will configure the trigger event in Pabbly Connect. Select Typeform as your application and choose the trigger event as ‘New Entry’. This means that every time someone submits a form, it will trigger the workflow.
- Select Typeform as the application.
- Choose the trigger event ‘New Entry’.
- Connect your Typeform account by granting permission.
Once connected, choose the specific form you want to use. This allows Pabbly Connect to capture the responses from the selected Typeform.
3. Performing a Test Submission in Typeform
After setting up the trigger, it’s time to perform a test submission. Go to your Typeform and fill it out with dummy details. This step is crucial as it allows Pabbly Connect to capture the data from the form submission.
Make sure to enter details such as name, email, and phone number. After submitting the form, return to Pabbly Connect, where you should see the captured data displayed. This confirms that the integration is working correctly.
4. Configuring the MailerLite Action in Pabbly Connect
Next, you will set up the action event in Pabbly Connect to create a subscriber in MailerLite. Select MailerLite as the application and choose the action event ‘Create Subscriber’. This will allow you to add the captured Typeform entries as subscribers in MailerLite.
- Select MailerLite as the application.
- Choose the action event ‘Create Subscriber’.
- Connect your MailerLite account using the API token.
Map the fields from the Typeform submission to the MailerLite fields. For instance, map the email address and name from Typeform to the corresponding fields in MailerLite. This ensures that the data flows correctly through Pabbly Connect.
After mapping the fields, click on the button to finalize the integration. Once completed, you should see a confirmation that a subscriber has been added to MailerLite. This confirms that the integration through Pabbly Connect is successful.
To test the setup, submit another entry through your Typeform. Check MailerLite to ensure that the new subscriber appears with the correct details. This real-time synchronization eliminates the need for manual CSV exports.
In this tutorial, we explored how to use Pabbly Connect to automate the addition of Typeform entries as subscribers in MailerLite. This integration streamlines your workflow and saves time by eliminating manual data entry.
