Learn how to seamlessly add subscribers to ActiveCampaign after a successful Instamojo payment using Pabbly Connect. Follow our step-by-step tutorial for easy integration. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To begin integrating ActiveCampaign and Instamojo, you need to access Pabbly Connect. Start by visiting the Pabbly Connect website at Pabbly.com/connect.
If you are a new user, sign up for an account, which takes just a couple of minutes. Upon signing up, you will receive 100 free tasks to get started with your automation.
After logging into Pabbly Connect, navigate to the dashboard and click on ‘Create Workflow’. You will be prompted to name your workflow, which can be something like ‘Instamojo to ActiveCampaign’.
This workflow will automate the process of adding subscribers to ActiveCampaign whenever a successful payment is made through Instamojo. Click on ‘Create’ to proceed to the next steps.
3. Set Up Trigger Event for Instamojo
In this section, you will set up the trigger event for your workflow. Select Instamojo as your trigger application and choose the event ‘New Sale’. This event will activate the workflow every time a new sale occurs.
Once selected, Pabbly Connect will provide a webhook URL. Copy this URL as you will need to add it to your Instamojo account. This URL acts as a bridge between Pabbly Connect and Instamojo.
- Select ‘New Sale’ as the trigger event.
- Log into your Instamojo account to add this webhook.
After copying the URL, proceed to your Instamojo account settings to add this webhook. This step is crucial for ensuring that Pabbly Connect receives payment data from Instamojo.
4. Configure Instamojo to Use the Webhook
In your Instamojo account, navigate to the Smart Pages section where you can customize your payment pages. Here, you will add the webhook URL you copied from Pabbly Connect.
After pasting the webhook URL, save the settings. This ensures that every time a payment is processed, the data will be sent to Pabbly Connect, triggering the next steps in your workflow.
- Go to Smart Pages and select the page for your product.
- Add the copied webhook URL in the settings.
- Save the changes to update the page.
Now, you are ready to perform a test payment to ensure everything works correctly. This will allow you to see the data being captured in Pabbly Connect.
5. Add Subscriber to ActiveCampaign
After a successful payment through Instamojo, the next step is to add the subscriber to ActiveCampaign using Pabbly Connect. In your workflow, select ActiveCampaign as the action application and choose the event ‘Create Contact’.
To connect Pabbly Connect with ActiveCampaign, you will need your ActiveCampaign API URL and Key. Access these from your ActiveCampaign account under the settings menu. Once you have these, paste them into Pabbly Connect to establish the connection.
Select ‘Create Contact’ as the action event. Enter your ActiveCampaign API URL and Key. Map the fields from the payment data to the contact fields in ActiveCampaign.
Once mapped, test the connection to ensure that the subscriber is added successfully to ActiveCampaign. This completes the integration process, allowing you to automatically add subscribers after successful payments.
In this tutorial, we demonstrated how to use Pabbly Connect to add subscribers to ActiveCampaign following successful payments on Instamojo. By following these steps, you can automate your subscriber management efficiently.
Utilizing Pabbly Connect streamlines your workflow, ensuring that every payment translates into a new subscriber in your ActiveCampaign account seamlessly.
