Learn how to automate adding students to ThriveCart Learn using Razorpay payments with Pabbly Connect. Step-by-step tutorial for seamless integration. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
1. Introduction to Pabbly Connect for Automation
In this section, we will explore how to use Pabbly Connect to automate the process of adding students to ThriveCart Learn whenever a payment is made via Razorpay. This integration is essential for streamlining course enrollment.
By utilizing Pabbly Connect, you can create a seamless workflow that triggers automatically upon payment confirmation. This eliminates manual entry, ensuring that all students are promptly added to your course.
2. Setting Up Your Pabbly Connect Workflow
To start, log into your Pabbly Connect account and navigate to the dashboard. Click on the ‘Create Workflow’ button to initiate a new automation workflow. You will be prompted to name your workflow, such as ‘Razorpay to ThriveCart Learn’, and select a folder for organization.
- Click on ‘Create’ to open the workflow setup.
- Select Razorpay as the app and choose ‘Payment Captured’ as the trigger event.
After setting up the trigger, you will need to configure Razorpay to send payment details to Pabbly Connect. This involves adding the webhook URL in your Razorpay account settings.
3. Configuring Razorpay Webhook for Pabbly Connect
Next, head over to your Razorpay dashboard. In the account settings, locate the ‘Webhooks’ option. Click on ‘Add New Webhook’ and paste the copied URL from Pabbly Connect into the designated field.
- Leave the secret and alert email fields empty.
- Select ‘Payment Captured’ as the active event.
Once you click on ‘Create’, Razorpay will now send payment notifications to Pabbly Connect. This step is crucial for ensuring that the automation workflow is triggered whenever a payment is successfully processed.
4. Filtering Payments in Pabbly Connect
After setting up the webhook, it is important to filter the received payment data. This ensures that only relevant payments for your specific course are processed. In Pabbly Connect, add a filter condition that checks if the payment details correspond to your course.
Select ‘Filter’ as the app and choose ‘Filter Values’ as the action event. Set the condition to check if the course name matches your PHP programming course.
This filter ensures that only students who have paid for the specific course are added to ThriveCart Learn. If the condition is met, you can proceed to add the student with the appropriate details.
5. Adding Students to ThriveCart Learn
In the final step, you will set up the action to add the student to your ThriveCart Learn account. In Pabbly Connect, select ThriveCart Learn as the action app and choose ‘Create New Student’ as the action event.
Connect your ThriveCart Learn account using the API key. Map the customer’s email and name from Razorpay to the corresponding fields.
Once all details are mapped, click on ‘Save and Send Test Request’. If successful, the student will be added to your ThriveCart Learn course, completing the automation process using Pabbly Connect.
In this tutorial, we demonstrated how to use Pabbly Connect to automate the addition of students to ThriveCart Learn upon receiving payments via Razorpay. This integration streamlines your enrollment process, ensuring a seamless experience for both you and your students.
