Learn how to seamlessly add students to your Uteach bundle from ThriveCart purchases using Pabbly Connect. This detailed guide covers all steps for automation. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To get started with adding students to your Uteach bundle from ThriveCart purchases, you need to access Pabbly Connect. This integration platform allows you to automate the process seamlessly. Begin by navigating to the Pabbly Connect website in your browser.
Once there, you can either sign in if you have an account or click on the ‘Sign up for free’ button to create a new account. Signing up is quick and grants you 100 free tasks each month, which is sufficient for initial testing.
After logging into Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button, which prompts you to name your workflow. In this case, name it something descriptive like ‘Add Student to Uteach Bundle from ThriveCart Purchase’.
Next, select the folder where you want to save your workflow. You can create a new folder or select an existing one. After selecting the folder, click on ‘Create’ to proceed. This action will take you to the workflow setup page, where you will define the trigger and action for your integration.
  • Click ‘Create Workflow’
  • Name your workflow
  • Select or create a folder
After setting up your workflow, you will see two boxes labeled ‘Trigger’ and ‘Action’. The trigger will initiate the workflow when a new purchase is made on ThriveCart.
3. Setting Up the Trigger for ThriveCart
The next step is to set up the trigger in Pabbly Connect. For this integration, select ‘ThriveCart’ as your trigger application. After selecting it, you will need to choose the trigger event, which in this case is ‘Product Purchase’.
To connect ThriveCart with Pabbly Connect, click on ‘Connect’ and then choose ‘Add New Connection’. You will be prompted to enter an API token from ThriveCart. To obtain this token, go to your ThriveCart account, access the settings, and create a new API key under API settings.
  • Select ‘ThriveCart’ as the trigger application
  • Choose ‘Product Purchase’ as the trigger event
  • Obtain API token from ThriveCart settings
After entering the token in Pabbly Connect, save the connection. This setup will ensure that every time a purchase is made, the workflow is triggered, allowing you to add the student to your Uteach bundle automatically.
4. Configuring the Action to Add Student in Uteach
Now that the trigger is set up, it’s time to configure the action in Pabbly Connect. For the action application, select ‘Uteach’. Then, choose ‘Create Student’ as the action event. This step is crucial as it allows you to create a new student profile based on the purchase information from ThriveCart.
To connect Uteach with Pabbly Connect, you will need to provide your domain and API key from your Uteach account. Navigate to the settings in Uteach, find the integration settings, and retrieve your API details.
Select ‘Uteach’ as the action application Choose ‘Create Student’ as the action event Input domain and API key from Uteach
Once connected, map the student’s name and email address from the ThriveCart response to the respective fields in Uteach. This mapping ensures that the correct information is used to create the student profile.
After configuring the action steps, you will need to finalize the integration in Pabbly Connect. This involves adding the student to the specific course bundle in Uteach. Select ‘Add Student to Bundle’ as the final action event.
Here, you will again map the student’s email address and provide the bundle slug, which can be found in your Uteach account under the marketing section. This slug is essential for identifying the correct course bundle.
Once everything is set, click on ‘Save and Send Test Request’. If the integration is successful, you will see a response confirming that the student has been added to the Uteach bundle. You can verify this by checking the student list in your Uteach account to ensure that the new student appears correctly.
In this tutorial, we demonstrated how to use Pabbly Connect to automate the process of adding students to a Uteach bundle from ThriveCart purchases. By following these steps, you can streamline your enrollment process and enhance the experience for both you and your students.
Utilizing Pabbly Connect not only saves time but also minimizes manual errors, ensuring a seamless educational experience. Start automating your processes today with Pabbly Connect!
