Learn how to integrate Shopify with MailerLite using Pabbly Connect to automatically add customers as subscribers. Follow our step-by-step guide for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To start the integration process, access Pabbly Connect. This platform allows you to automate workflows between Shopify and MailerLite seamlessly. First, sign in to your Pabbly Connect account.
Once logged in, navigate to the dashboard where you can create a new workflow. This is where you will set up the automation to add Shopify customers as subscribers to MailerLite.
In this step, you will create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button and give your workflow a name, such as ‘Shopify to MailerLite Integration’.
Next, select the trigger application. Choose Shopify and the trigger event as ‘New Customer Created’. This ensures that every time a new customer is added in Shopify, the integration will automatically trigger.
- Click on the ‘Save’ button to proceed.
- Connect your Shopify account by following the on-screen instructions.
- Once connected, test the trigger to ensure it captures customer data accurately.
This setup in Pabbly Connect will capture new customer details effectively, allowing you to move to the next step of adding them to MailerLite.
3. Setup MailerLite Action in Pabbly Connect
Now, you will set up the action for MailerLite in Pabbly Connect. After successfully testing the Shopify trigger, choose MailerLite as the action app. Select the action event as ‘Add Subscriber’.
In this section, you will map the fields from Shopify to MailerLite. Enter the necessary details such as email, first name, last name, and any other relevant customer information. This ensures that the subscriber’s data is correctly populated in MailerLite.
- Map the email address from Shopify to the email field in MailerLite.
- Fill in additional fields like first name and last name as required.
- Click on the ‘Save’ button to finalize the action setup.
This integration step in Pabbly Connect ensures that every new Shopify customer is automatically added to your MailerLite subscriber list.
4. Test Your Integration in Pabbly Connect
Testing your integration is crucial to ensure everything works smoothly. In Pabbly Connect, after setting up your action, click on the ‘Test & Review’ button. This will simulate the process of adding a subscriber to MailerLite.
Check MailerLite to confirm that the new subscriber has been added successfully. If the test is successful, you will see the customer details reflected in your MailerLite account. If there are any errors, review the mapping and settings in Pabbly Connect to make necessary adjustments.
Once everything is confirmed to be working, turn on your workflow in Pabbly Connect. This will activate the integration, allowing for real-time updates when new customers are created in Shopify.
In conclusion, using Pabbly Connect allows you to seamlessly integrate Shopify with MailerLite, automatically adding new customers as subscribers. This integration enhances your email marketing efforts and improves customer engagement.
