Learn how to seamlessly add leads to Brevo from Kit using Pabbly Connect for effective cross-channel automation. Follow our step-by-step guide! Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To start adding leads to Brevo from Kit, you first need to access Pabbly Connect. Open your web browser and enter the URL Pabbly.com/connect. This will take you to the Pabbly Connect landing page.
Once there, you will see options to either sign in or sign up for free. If you are a new user, click on the ‘Sign Up Free’ button to create an account. This allows you to utilize Pabbly Connect with 100 free tasks every month for practice. If you already have an account, simply log in.
After logging into Pabbly Connect, navigate to your dashboard where you can create a new workflow. Click on the ‘Create Workflow’ button to begin the process of integrating Kit and Brevo.
  • Select the workflow builder (Beta or Classic).
  • Name your workflow (e.g., ‘Create Contact in Brevo for New Kit Subscribers’).
  • Choose a folder for your workflow.
Once you have set the name and folder, click the ‘Create’ button. You will now see the option to add a trigger, which is essential for starting the workflow.
3. Setting Up the Trigger with Kit
The next step involves setting up the trigger in Pabbly Connect. Click on the ‘Add Trigger’ button and select Kit as your trigger application. This will initiate the workflow whenever a new subscriber is added.
For the event, choose ‘New Form Subscriber’. After that, click on the ‘Connect’ button to establish a connection with Kit. You will need your API key and API secret from Kit to complete this process.
  • Go to your Kit account and navigate to the profile settings.
  • Select ‘Developer’ to find your API key and secret.
Copy the API key and secret back to Pabbly Connect to finalize the connection. Once connected, select your form and click ‘Save and Send Test Request’ to check if the setup works correctly.
4. Adding an Action Step to Create Leads in Brevo
With the trigger successfully set up, the next step is to add an action in Pabbly Connect. Click on the ‘Add New Action Step’ button and select Brevo as your action application. Choose the event ‘Create or Update Contact’.
Click on ‘Connect’ to link Brevo with Pabbly Connect. You will need to enter your Brevo domain and API key. To obtain the API key, go to your Brevo account, navigate to the SMTP and API page, and generate a new API key.
Enter the API key generated in Brevo into Pabbly Connect. Map the fields from Kit to Brevo (e.g., email, first name, last name).
After mapping the necessary fields, click ‘Save and Send Test Request’ to ensure that the lead is created successfully in Brevo.
5. Testing the Integration
Now that the setup is complete, it’s time to test the integration. Fill out the subscriber form in Kit with sample data. Once submitted, check Pabbly Connect to see if the response from Kit is received correctly.
After confirming the data is received, check your Brevo account to verify that the new contact has been created. You should see the details of the new subscriber reflected in your Brevo contact list.
This testing phase ensures that the entire workflow is functioning as intended, allowing you to automate the process of adding leads to Brevo from Kit seamlessly.
In this tutorial, we demonstrated how to use Pabbly Connect to add leads to Brevo from Kit for effective cross-channel automation. By following the steps outlined, you can easily automate your lead generation process without any coding skills.
Utilizing Pabbly Connect simplifies the integration process, allowing businesses to focus on growth and efficiency. Start using Pabbly Connect today to enhance your automation capabilities!
