Learn how to integrate Kajabi with Mailchimp using Pabbly Connect for automatic subscriber management. Follow this detailed guide to streamline your marketing efforts. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
1. Accessing Pabbly Connect for Kajabi Mailchimp Integration
To automate adding Kajabi customers to Mailchimp as subscribers automatically, you will first need to access Pabbly Connect. This powerful integration platform allows you to connect various applications seamlessly.
Start by signing up for a free account at Pabbly Connect. If you’re already a user, simply log in to your dashboard. Once logged in, click on the ‘Create Workflow’ button to begin setting up your automation.
After accessing your Pabbly Connect dashboard, you will need to create a workflow for the integration. Name your workflow something descriptive, like ‘When Purchase is Made in Kajabi, Create Contact in Mailchimp’. This name will help you identify the automation later.
- You will see two boxes: Trigger and Action.
- Select ‘Kajabi’ as the Trigger application.
Setting the trigger is crucial for your automation. In this case, you want to select the event that occurs when a new purchase is made in Kajabi. This will initiate the process to add the customer to Mailchimp using Pabbly Connect.
3. Connecting Kajabi to Pabbly Connect
To connect Kajabi with Pabbly Connect, you will need to set up a webhook URL. This URL will allow Pabbly Connect to receive data from Kajabi whenever a purchase is made.
Copy the webhook URL provided by Pabbly Connect and navigate to your Kajabi dashboard. Open the specific course for which you want to capture customer data, and go to the offer section. Here, click on the three dots to find the ‘Webhooks’ option.
- Paste the copied webhook URL into the designated field.
- Click on ‘Save’ to update the offer with the webhook.
- Return to Pabbly Connect and click on ‘Recapture Webhook Response’.
This step ensures that any new purchase made in Kajabi will trigger the webhook, allowing Pabbly Connect to capture the purchase details automatically.
4. Testing the Integration with a Dummy Purchase
To ensure your automation is working correctly, perform a test purchase in Kajabi. Navigate back to your Kajabi checkout page and complete a dummy purchase using test customer details. using Pabbly Connect
As you make this purchase, Pabbly Connect will capture the details of the transaction. You should see the customer information, such as name and email address, reflected in the Pabbly Connect dashboard shortly after the purchase.
Ensure the customer details are accurate and complete. Verify that Pabbly Connect has received the webhook response. This confirms that your integration is set up correctly.
Once you confirm the details are received, you can proceed to connect Mailchimp to Pabbly Connect, allowing you to add the captured customer data as a new subscriber.
5. Adding Kajabi Customers to Mailchimp as Subscribers Automatically
Now that you have captured the customer details in Pabbly Connect, the next step is to add this information to Mailchimp. Select ‘Mailchimp’ as the action application in your workflow.
Connect Mailchimp to Pabbly Connect by entering your Mailchimp API key and data center. You can find the API key in your Mailchimp account under the profile settings in the extras section.
Choose the audience list where you want to add the new subscribers. Map the fields from the Kajabi purchase data to the corresponding fields in Mailchimp. Click on ‘Save’ to finalize the integration.
Once this is complete, every time a new purchase is made in Kajabi, the customer will be automatically added as a subscriber in Mailchimp through Pabbly Connect. This automation saves you time and ensures that your marketing efforts are always up to date.
By using Pabbly Connect, you can automate the process of adding Kajabi customers to Mailchimp as subscribers automatically. This integration streamlines your workflow, ensuring that your marketing lists are always current with new customer data.
