Learn how to integrate Housing.com leads with Mailchimp automatically using Pabbly Connect in this step-by-step tutorial. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To start automating the addition of Housing.com leads to Mailchimp, we first need to access Pabbly Connect. Open a new tab in your browser and type Pabbly.com/connect to reach the Pabbly Connect landing page.
Once on the landing page, you will find options to either sign in or sign up for free. If you are a new user, click on sign up for free to get started. Existing users should click on sign in to access their dashboard. After signing in, navigate to the Pabbly Connect application and click on access to enter the dashboard.
Now that you are in the Pabbly Connect dashboard, the next step is to create a workflow. Click on the create workflow button. You will be prompted to choose between the new workflow builder and the classic one. Select the Pabbly Connect new workflow builder for a more modern interface.
- Enter a name for your workflow.
- Select a folder to save your workflow.
- Click on create to open the workflow editor.
This will direct you to the workflow window, where you can set up triggers and actions. The trigger will initiate the workflow when a new lead is received from Housing.com.
3. Setting Up the Trigger with Housing.com
In the workflow window, click on the add trigger button. Search for Housing.com as your trigger application and select it. For the trigger event, choose new leads and click connect.
You will receive a webhook URL that needs to be added to your Housing.com account. Since the Housing.com portal does not allow users to add webhook URLs directly, contact your account manager and provide them with the webhook URL. Once they add it, Pabbly Connect will start capturing lead details automatically.
4. Adding Action to Mailchimp in Pabbly Connect
After setting up the trigger, click on the add new action step. Search for Mailchimp as your action application and select it. Choose the event add new member with custom fields and click connect.
- Select add a new connection to create a new Mailchimp connection.
- Log into your Mailchimp account and navigate to profile settings.
- Generate a new API key under extras > API keys.
Copy the generated API key and paste it into Pabbly Connect. You will also need to enter your Mailchimp data center, which can be found in the URL of your Mailchimp account. After entering these details, click on save to connect Mailchimp with Pabbly Connect.
With Mailchimp connected, you need to select the audience list and map the required fields. For the email address, use the mapping feature to dynamically insert the email from the Housing.com lead. You can also add optional fields like first name and last name.
Once you have mapped the fields, click on save and send test request. If successful, you will see a confirmation message. Check your Mailchimp audience to verify that a new member has been added with the lead details.
This integration allows you to automatically add new leads from Housing.com to Mailchimp, enabling you to nurture your leads through email campaigns without manual effort. With Pabbly Connect, this entire process is seamless and efficient.
In this tutorial, we successfully demonstrated how to use Pabbly Connect to automatically add Housing.com leads to Mailchimp. Following these steps allows for effortless lead management and email marketing.
