Learn how to seamlessly integrate Heights Platform and MailerLite to automatically add student data using Pabbly Connect. Step-by-step tutorial included. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
To begin the process of adding Heights platform students’ data to MailerLite as subscribers, you need to access Pabbly Connect. This platform serves as the central hub for integrating various applications seamlessly. Start by visiting the Pabbly Connect website and signing up for a free account if you are a new user.
After logging in, you will be directed to the dashboard. Here, you can create a new workflow by clicking on the blue button. Name your workflow something like ‘Add Heights Platform Students Data to MailerLite as Subscribers’ and click on ‘Create’ to proceed with the automation setup.
2. Setting Up the Trigger with Heights Platform
In this section, you will configure the trigger that initiates the automation whenever a new student signs up on the Heights platform. In Pabbly Connect, select Heights platform as your trigger application. Then choose the trigger event as ‘New Student Signup’ to ensure that the automation activates upon a new registration.
- Choose ‘Heights Platform’ as the trigger application.
- Select the trigger event as ‘New Student Signup’.
- Click on ‘Connect’ to establish the connection with the Heights platform.
To connect Heights platform with Pabbly Connect, you will need to provide the subdomain and API key. Copy your subdomain from the Heights platform URL and paste it into the connection settings. Then, retrieve your API key from the account settings section of the Heights platform and input it into Pabbly Connect.
3. Capturing Student Data from Heights Platform
Once the connection is established, Pabbly Connect will allow you to capture data from the Heights platform. Click on the ‘Save and Send Test Request’ button to capture the most recent student data. This step is crucial as it verifies that the integration is working correctly.
To test the integration, sign up a new student on the Heights platform using dummy details. After signing up, return to Pabbly Connect to see if the student data has been captured successfully. The response should include the student’s name and email address, confirming that the trigger is functioning as intended.
4. Setting Up the Action to Create Subscribers in MailerLite
Now that you have captured the student data, the next step is to set up the action in Pabbly Connect to create a subscriber in MailerLite. Select MailerLite as your action application and choose the action event as ‘Create or Update Subscriber’.
- Select ‘MailerLite’ as the action application.
- Choose the action event as ‘Create or Update Subscriber’.
- Connect your MailerLite account using the API token from your MailerLite dashboard.
After connecting, map the fields from the captured student data to the corresponding fields in MailerLite, such as email address and student name. Ensure that you select the appropriate subscriber status (e.g., ‘Active’) and leave other fields blank unless necessary.
With everything set up, it’s time to finalize the integration. Click on the ‘Save and Send Test Request’ button in Pabbly Connect to test the entire workflow. If the integration is successful, the new student should be added as a subscriber in MailerLite.
To verify, check the subscriber section in your MailerLite account. You should see the new subscriber listed there. This confirms that the automation is working correctly and that all future student signups from Heights platform will automatically be added to MailerLite as subscribers.
Using Pabbly Connect, you can easily integrate Heights platform with MailerLite to automate the process of adding new student data as subscribers. This integration streamlines your workflow and ensures that your email marketing efforts are always up-to-date with your latest student enrollments.
