Learn how to integrate Facebook Leads with Google Sheets for your travel and tourism business using Pabbly Connect. Step-by-step tutorial included. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
1. Accessing Pabbly Connect for Facebook Leads Integration
To automate the process of adding Facebook leads to Google Sheets for your travel and tourism business, you need to access Pabbly Connect. Start by visiting the Pabbly Connect website and signing up for a free account if you are a new user. This process is quick and provides you with 100 free tasks to explore the features.
After signing in, you will reach the dashboard of Pabbly Connect. Here, you can create new workflows that automate the integration of Facebook leads into Google Sheets. Click on the ‘Create Workflow’ button located in the top right corner to begin.
2. Creating the Workflow in Pabbly Connect
Once you click on ‘Create Workflow,’ a dialog box will appear asking for a name. Name your workflow something descriptive like ‘Add Facebook Leads to Google Sheets’. After naming, select the folder to save your workflow and click on ‘Create’. using Pabbly Connect
- Choose the folder for organization.
After creating the workflow, you will see two sections: Trigger and Action. Select Facebook Lead Ads as your trigger application and choose the event ‘New Lead Instant’. This sets up your workflow to initiate whenever a new lead is generated from Facebook.
To connect Facebook Lead Ads with Pabbly Connect, you need to establish a new connection. Click on ‘Connect’ and select ‘Add New Connection’. Then, click on the ‘Connect with Facebook Lead Ads’ button. Ensure you are logged into your Facebook account, as this will simplify the authorization process.
Once connected, select the appropriate Facebook page and the lead generation form you created for your travel and tourism business. After selecting these, click on ‘Save and Send Test Request’ to fetch a test lead response, which will be critical for the next steps.
4. Mapping Lead Details to Google Sheets
After successfully receiving the lead data from Facebook, the next step is to map these details into Google Sheets using Pabbly Connect. For this, select Google Sheets as your action application and choose the action event ‘Add New Row’. This allows new lead information to be added as a new row in your spreadsheet.
- Select your Google Sheets account to connect.
- Choose the spreadsheet named ‘Facebook Leads’.
- Map the fields: First Name, Last Name, Email, and Phone Number.
After mapping the fields, click on ‘Save and Send Test Request’ to verify that the data is correctly sent to your Google Sheets. Check your spreadsheet to confirm that a new row has been added with the lead details.
5. Testing the Integration for Success
To ensure everything is working correctly, perform a test submission using the Facebook Lead Ads Testing Tool. Fill out the form with dummy data and submit it. This will simulate a new lead being generated and allow you to see if the details are captured in your Google Sheets through Pabbly Connect.
After submitting the test lead, return to your Google Sheets and verify that the new lead information appears as expected. This confirms that your integration is successful and that every new lead from Facebook will automatically be recorded in your Google Sheets, streamlining your workflow for your travel and tourism business.
Integrating Facebook leads with Google Sheets using Pabbly Connect significantly enhances the efficiency of managing leads for your travel and tourism business. This automation ensures that every new lead is captured seamlessly, allowing you to focus on growing your business.
