Learn how to automate the process of adding Facebook leads to Google Sheets for Polymer Industries using Pabbly Connect. Step-by-step tutorial included. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To automate adding Facebook leads to Google Sheets, you need to access Pabbly Connect. First, navigate to the Pabbly Connect landing page and sign up if you are a new user or sign in if you already have an account.
Once you are logged in, you will see the dashboard. Click on the ‘Create Workflow’ button located at the top right corner. This is where you will set up your integration between Facebook leads and Google Sheets.
In the ‘Create Workflow’ dialog box, name your workflow, for instance, ‘Poly Crafters Facebook Lead Ads to Google Sheets’. You can also select a folder for better organization of your workflows. using Pabbly Connect
- Select a folder to organize your workflows.
After naming your workflow, click on the ‘Create’ button. This will open the workflow window where you can set your trigger and action.
The next step is to set up your trigger. For this integration, select ‘Facebook Lead Ads’ as your trigger application and choose ‘New Lead’ as the trigger event. This means that whenever a new lead is generated, Pabbly Connect will capture the response immediately.
To connect your Facebook account, click on ‘Connect’ and then ‘Add New Connection’. Once authorized, select your Facebook page and the lead generation form you want to use. Click on ‘Save and Send Test Request’ to ensure the connection works properly.
4. Setting Up the Action in Google Sheets
Now that your trigger is set, it’s time to define the action. Select ‘Google Sheets’ as your action application and choose ‘Add New Row’ as the action event. This allows Pabbly Connect to add new lead details to your Google Sheets automatically.
- Click on ‘Connect’ to build a new connection with Google Sheets.
- Sign in with your Google account and authorize access.
- Select the spreadsheet you created for Facebook leads.
Map the fields from your Facebook lead form to the corresponding columns in your Google Sheets. For example, map the full name, email, and phone number from the lead details.
5. Testing the Automation
To ensure your integration is functioning correctly, it’s important to test the automation. Go back to the Facebook Lead Ads testing tool and submit a new lead. After submitting, check your Google Sheets to see if the new lead information appears as a new row.
If the lead details are successfully added to your Google Sheets, your automation is working! You can repeat the test by deleting the previous lead and submitting a new one to verify that Pabbly Connect captures all new leads accurately.
This tutorial demonstrated how to use Pabbly Connect to automate the process of adding Facebook leads to Google Sheets for Polymer Industries. By following these steps, you can efficiently manage leads and streamline your business operations.
