Learn how to integrate Elementor form leads with Kit automation using Pabbly Connect in this detailed step-by-step tutorial. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Access Pabbly Connect for Automation
To start integrating Elementor form leads with Kit automation, you first need to access Pabbly Connect. Simply open your browser and search for the Pabbly Connect landing page by entering ‘Pabbly.com/connect’. This will take you to the main interface where you can manage your automation workflows.
Once on the Pabbly Connect page, you have the option to sign in or sign up for free. If you are a new user, click on ‘Sign up for free’ to get started with 100 free tasks every month. Existing users can click on ‘Sign in’ to access their accounts. After signing in, you will see all the Pabbly applications, and you should click on ‘Access Now’ under Pabbly Connect to begin.
Now that you are in Pabbly Connect, the next step is to create a new workflow. Click on the button that says ‘Create Workflow’. You will be prompted to choose between the new workflow builder and the classic one. For a modern interface, select the new workflow builder.
- Click on ‘Create Workflow’.
- Select the ‘New’ workflow builder.
- Name your workflow (e.g., ‘Add Elementor Form Leads to Kit Automation’).
Choose a folder to save your workflow, such as ‘Automation’. Once you have named your workflow and selected a folder, click on ‘Create’. This will take you to the workflow window where you can set up your triggers and actions.
3. Set Up the Trigger with Elementor
The next step in Pabbly Connect is to set up a trigger. Click on ‘Add Trigger’ and select ‘Elementor’ as your trigger application. For the trigger event, choose ‘New Form Submission’. After selecting the trigger event, click on ‘Connect’. This will generate a webhook URL.
Copy the generated webhook URL and navigate to your Elementor form settings. In the form settings, find the ‘Actions After Submit’ section and add a new action named ‘Webhook’. After adding the webhook action, paste the copied URL into the designated field and click ‘Publish’. This connects your Elementor form to Pabbly Connect, allowing it to send data whenever a new form submission occurs.
4. Add Action to Create Subscriber in Kit
Now that your trigger is set up, the next step is to add an action to create a subscriber in Kit. In Pabbly Connect, click on ‘Add New Action Step’ and select ‘Kit’ as the action application. For the action event, choose ‘Add Subscriber to a Form’ and click on ‘Connect’.
You will need to enter your Kit API key and API secret to establish the connection. To find these, go to your Kit dashboard, click on your profile picture, then navigate to ‘Settings’ and ‘Developer’. Copy the API key and secret and paste them into the respective fields in Pabbly Connect. After entering these credentials, click ‘Save’ to finalize the connection.
5. Map Fields and Test the Workflow
The final step in Pabbly Connect is to map the fields from your Elementor form to your Kit subscriber form. In the action setup, select the form you want to add subscribers to and map the necessary fields such as first name, last name, email, and mobile number. This mapping ensures that the data from the Elementor form is correctly transferred to Kit.
- Select the form from Kit where subscribers will be added.
- Map each field from Elementor to Kit (e.g., first name, last name, email).
- Click ‘Save and Send Test Request’ to verify the integration.
After testing the workflow, you should see the new subscriber added to your Kit account. Whenever a new form submission occurs in Elementor, the subscriber will be automatically created in Kit through Pabbly Connect.
In this tutorial, we explored how to effectively integrate Elementor form leads with Kit automation using Pabbly Connect. By following these steps, you can automate the process of adding subscribers to your Kit account seamlessly. This integration not only saves time but also enhances your workflow efficiency.
