Learn how to seamlessly integrate Boomerangme customers as Sendinblue contacts using Pabbly Connect with this detailed step-by-step tutorial. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To begin the integration process, first access Pabbly Connect by visiting the official Pabbly website. You will find options to sign in or sign up for a free account. Signing up grants you free tasks every month, so it’s beneficial to create an account if you don’t have one.
After signing into your account, navigate to the top right corner and click on the ‘Create Workflow’ button. When prompted, name your workflow, for example, ‘Boomerangme to Sendinblue’. This sets the stage for automating the process of adding customers from Boomerangme to Sendinblue using Pabbly Connect.
In this step, you will configure the trigger for your workflow. Select Pabbly Connect as the platform and choose Boomerangme as the trigger application. The specific trigger event you need is ‘New Customer’, which activates whenever a new customer is added in Boomerangme.
- Select Boomerangme as the trigger application.
- Choose ‘New Customer’ as the trigger event.
- Connect your Boomerangme account using your API key.
Once connected, save your settings and send a test request. You’ll need to create a dummy customer in Boomerangme to test if Pabbly Connect captures the information correctly, confirming the connection is successful.
3. Creating a Dummy Customer in Boomerangme
Next, you will create a dummy customer in your Boomerangme account. Navigate to the ‘Customers’ section and click on the ‘Add Customers’ button. Fill in the required fields, such as first name, last name, contact number, and email address. For this example, you might use names like ‘Dummy’ and ‘Demo’ to keep it simple.
After entering the customer details, click on ‘Add Customers’ to finalize the creation. Refresh the customers’ list to confirm that your dummy customer has been added successfully. This step is crucial as it will trigger Pabbly Connect to capture the new customer data when the test request is sent.
4. Setting Up the Action to Create Contacts in Sendinblue
Now that you have configured the trigger, it’s time to set up the action in Pabbly Connect. Select Sendinblue as the action application and choose ‘Create Contact’ as the action event. This means every time a new customer is added in Boomerangme, their details will be automatically sent to Sendinblue.
- Select Sendinblue as the action application.
- Choose ‘Create Contact’ as the action event.
- Connect your Sendinblue account using the API key.
To obtain the API key, log into your Sendinblue account, navigate to your username in the top right corner, and select ‘SMTP and API’. Create a new API key and copy it back to Pabbly Connect. This connection will allow you to map customer details from Boomerangme to Sendinblue.
5. Mapping Customer Details and Testing the Integration
In this final step, you will map the customer details from Boomerangme to Sendinblue. In Pabbly Connect, you will need to specify which customer details to send, such as first name, last name, email address, and contact number. This ensures that the correct information is transferred to Sendinblue.
After mapping the fields, click on ‘Save and Send Test Request’. This will send the mapped data to Sendinblue and create a new contact in your specified list. To verify the integration, refresh your Sendinblue contacts list and check if the dummy customer appears as expected.
This successful integration demonstrates how Pabbly Connect automates the process of adding Boomerangme customers as contacts in Sendinblue, streamlining your workflow efficiently.
In this tutorial, we explored how to use Pabbly Connect to integrate Boomerangme with Sendinblue, enabling automatic addition of new customers. Following these steps ensures a seamless workflow, enhancing your operational efficiency.
