Learn how to integrate ActiveCampaign with Typeform using Pabbly Connect to automate subscriber addition from form entries. Step-by-step tutorial included. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To start the process of adding ActiveCampaign subscribers from Typeform form entries, you need to access Pabbly Connect. Begin by navigating to the Pabbly Connect landing page at Pabbly.com/connect.
Once there, you will notice two options on the right side: ‘Sign In’ and ‘Sign Up for Free.’ If you are new to Pabbly Connect, click on ‘Sign Up’ to create an account. After signing up, you will receive 100 free tasks to help you get started.
After signing in, you will reach the all apps page. Click on ‘Access Now’ for Pabbly Connect to start creating your workflow. Here, you will see the ‘Create Workflow’ button on the right side. using Pabbly Connect
- Click on ‘Create Workflow’.
- Name your workflow, for example, ‘Add ActiveCampaign Subscribers from Typeform Form Entries’.
- Click on ‘Create’ to finalize the workflow setup.
This will take you to a new page where you will define your trigger and action events. The trigger application will be Typeform, and the action application will be ActiveCampaign.
3. Setting Up Typeform as the Trigger Event
In this step, you will set Typeform as your trigger application within Pabbly Connect. Click on Typeform and select ‘New Entry’ as the trigger event. This means that every time there is a new form submission, the workflow will run.
Next, you will need to connect your Typeform account. Click on ‘Connect’ and then select ‘Add New Connection’ to authorize Pabbly Connect to access your Typeform account. Once connected, you will receive a confirmation of the successful authorization.
4. Testing Typeform Integration with Pabbly Connect
Now that Typeform is set up, it’s time to test the integration. You need to perform a test submission to capture the API response. Go to your Typeform account and fill out the form you created, including fields such as first name, last name, phone number, and email address.
- Fill in the form with sample data.
- Submit the form to generate an entry.
After submission, return to Pabbly Connect and click on ‘Save and Send Test Request’. This will allow Pabbly Connect to capture the response from Typeform, which will include the data entered during the test submission.
5. Setting Up ActiveCampaign as the Action Event
With the test submission successful, the next step is to set ActiveCampaign as your action application in Pabbly Connect. Click on ActiveCampaign and select ‘Create a Contact’ as the action event. This action will create a new subscriber in ActiveCampaign based on the information received from Typeform.
To connect your ActiveCampaign account, click on ‘Connect’ and select ‘Add New Connection’. You will need to provide your API key and URL from your ActiveCampaign account. Make sure to copy only the specific part of the URL as instructed, omitting the ‘https://’ part.
After successfully connecting, you will map the fields from the Typeform submission to the corresponding fields in ActiveCampaign, ensuring that the correct data is sent. Finally, click on ‘Save and Send Test Request’ to confirm that the integration is working correctly.
In this tutorial, we explored how to add ActiveCampaign subscribers from Typeform form entries using Pabbly Connect. By following the steps outlined, you can automate the process of subscriber addition seamlessly. This integration not only saves time but also enhances your email marketing efforts.
