1. Setting Up Your Pabbly Connect Integration
To begin, you need to set up your Pabbly Connect integration. Start by logging into your Pabbly Connect account. Once logged in, navigate to the dashboard and click on the “Create Workflow” button.
Next, give your workflow a name that reflects its purpose. This will help you easily identify it later. After naming your workflow, select the applications you wish to integrate, such as Google Sheets and Mailchimp.
2. Connecting Google Sheets with Pabbly Connect
Connecting Google Sheets to Pabbly Connect is straightforward. First, choose Google Sheets as your trigger application. You will then be prompted to select a trigger event, such as “New Spreadsheet Row”.
After selecting the trigger, authorize Pabbly Connect to access your Google Sheets account. Follow these steps to complete the authorization:
- Click on the “Authorize” button.
- Log into your Google account.
- Allow Pabbly Connect access to your Google Sheets.
Once authorized, select the specific spreadsheet and worksheet you want to monitor for new rows. This will set up your trigger to start the automation process.
3. Setting Up Mailchimp as the Action Application
Now that you have Google Sheets set up, it’s time to configure Mailchimp as your action application in Pabbly Connect. Choose Mailchimp from the list of available applications.
Select the action event, such as “Add/Update Subscriber”. You will need to connect your Mailchimp account by clicking on the “Connect” button. Here’s how to do it:
- Enter your Mailchimp API key.
- Select the audience you want to add subscribers to.
- Map the fields from Google Sheets to Mailchimp, such as email and name.
After mapping the fields, test the action to ensure everything is working correctly. This will confirm that new rows in Google Sheets are successfully added to your Mailchimp audience.
4. Testing Your Workflow in Pabbly Connect
After setting up both applications, it’s crucial to test your workflow in Pabbly Connect. Click on the “Test Workflow” button to initiate the testing process. This will help you verify that data flows correctly between Google Sheets and Mailchimp.
During the test, monitor the results closely. Check your Mailchimp account to see if the subscriber was added successfully. If the test is successful, you will see a confirmation message in Pabbly Connect.
If you encounter any issues, double-check your field mappings and ensure that all required fields are filled out correctly. Once everything is confirmed, your integration is ready to go live!
5. Finalizing and Activating Your Pabbly Connect Workflow
Once testing is complete, it’s time to finalize your Pabbly Connect workflow. Click on the “Save” button to ensure all your settings are stored. This step is crucial for the automation to function properly.
After saving, activate your workflow by toggling the switch to “On”. This will enable the automation, allowing new entries in Google Sheets to automatically add subscribers to your Mailchimp audience.
To monitor your workflow, you can return to the Pabbly Connect dashboard. Here, you can view logs of all actions taken and troubleshoot any potential issues.
In this tutorial, you learned how to integrate Google Sheets and Mailchimp using Pabbly Connect. By following the exact steps outlined, you can automate your workflows efficiently.
