Learn how to generate 100% unique articles automatically using Pabbly Connect, Writesonic, and WordPress. Follow this detailed tutorial for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To begin generating unique articles automatically, first, you need to access Pabbly Connect. This platform serves as the central hub for integrating various applications like Google Sheets, Writesonic, and WordPress.
Head to the Pabbly Connect website and sign up for a free account. Once registered, you’ll be directed to the dashboard. Click on the ‘Create Workflow’ button to start setting up your automation. Name your workflow something descriptive, such as ‘Generate Articles Automatically,’ and click ‘Create’ to proceed.
In this step, we will set Google Sheets as the trigger application for our automation using Pabbly Connect. This means that every time you enter data into your Google Sheets, it will initiate the workflow.
- Open your Google Sheets and create a new sheet for blog titles and publishing dates.
- In Pabbly Connect, select Google Sheets as your trigger application.
- Choose the trigger event as ‘New or Updated Spreadsheet Row.’
After selecting the trigger, Pabbly Connect will provide a webhook URL. This URL needs to be set up in your Google Sheets for the integration to work. Follow the instructions provided by Pabbly Connect to connect your Google Sheets to the workflow.
3. Connecting Writesonic for Article Generation
Once your Google Sheets are integrated with Pabbly Connect, the next step is to connect Writesonic. This AI content generation tool will create articles based on the titles you input in your spreadsheet.
In the action tab of Pabbly Connect, search for Writesonic and select it. Choose the action event as ‘Chatsonic.’ After connecting, you will need to enter your Writesonic API key, which you can find in your Writesonic account under the API dashboard.
- Map the blog title from your Google Sheets into the input text field for Writesonic.
- Set any additional parameters as needed and save the action.
After saving, test the action to ensure that Writesonic generates an article based on the title you provided in your Google Sheets. The response should show the generated article content.
4. Publishing Articles to WordPress
With the article generated by Writesonic, the final step is to publish it on your WordPress site using Pabbly Connect. In the action tab, search for WordPress and select it as your next action application.
Choose the action event as ‘Create a Post.’ You will need to connect to your WordPress account by entering your username, password, and base URL (excluding any additional paths like /wp-admin).
Map the post title and content retrieved from Writesonic into the corresponding fields in WordPress. Select the post status (e.g., published or draft) and any additional settings you require.
Finally, save and test this action. If successful, your article will be published on your WordPress site automatically whenever you add a new row in Google Sheets.
5. Finalizing Your Automation Setup
Now that you have connected Google Sheets, Writesonic, and WordPress through Pabbly Connect, your automation is complete. This setup allows you to generate and publish articles automatically without manual intervention.
To finalize, ensure that your workflow is active. Every time you add a new blog title and date in your Google Sheets, the integration will trigger, generating a unique article via Writesonic and publishing it to your WordPress site.
This seamless process not only saves time but also ensures that your content remains fresh and unique. You can now focus on other aspects of your blogging while the automation handles article generation and publishing.
Using Pabbly Connect to automate the generation and publication of unique articles is a game-changer for content creators. By integrating Google Sheets, Writesonic, and WordPress, you can streamline your content workflow and ensure consistent output without the hassle of manual entry.
