Learn how to automate LinkedIn posts from company milestones using Pabbly Connect. This step-by-step tutorial guides you through the integration process with Google Sheets and AI.
To generate LinkedIn posts from company milestones, the first step is to access Pabbly Connect. This platform enables seamless integration between Google Sheets and LinkedIn.
Visit the Pabbly Connect website and either sign in or sign up for a free account. Once logged in, you will be directed to the Pabbly apps window where you can select Pabbly Connect to start creating your workflow.
After accessing Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button located in the top right corner of the dashboard.
When prompted, name your workflow ‘AI is going to generate LinkedIn posts from company milestones’. Select the appropriate folder for organization. After naming and selecting the folder, click on the ‘Create’ button to finalize your workflow creation.
  • Click on ‘Create Workflow’.
  • Name your workflow accordingly.
  • Select the appropriate folder.
  • Click ‘Create’ to finalize.
This sets the stage for the automation process using Pabbly Connect, where you will define triggers and actions.
3. Setting Up the Trigger for Google Sheets
The next step involves setting up the trigger for your workflow. Choose Google Sheets as the trigger application. The trigger event will be set to ‘New or Updated Spreadsheet Row’.
After selecting your trigger application, Pabbly Connect will provide a webhook URL. Copy this URL and head to your Google Sheets to connect it with Pabbly Connect.
  • Open Google Sheets and navigate to Extensions.
  • Install the Pabbly Connect Webhooks add-on if not already done.
  • Paste the copied webhook URL in the setup dialog.
  • Choose the trigger column that contains the final data.
After setting this up, ensure you click on ‘Send on Event’ so that any new data added will trigger the automation.
4. Setting Up Action with OpenAI
Once the trigger is configured, the next step is to set up the action using OpenAI. Select OpenAI as the action application and choose ‘Chat GPT’ as the action event.
To connect OpenAI with Pabbly Connect, you will need to generate an API token. Follow the prompts to create a new secret key in your OpenAI account, copy it, and paste it into Pabbly Connect.
Select OpenAI as the action application. Generate a new API token in OpenAI. Paste the token into the connection field in Pabbly Connect. Configure the prompt for content generation.
This action will allow Pabbly Connect to generate LinkedIn post content based on the milestone data entered in Google Sheets.
5. Creating and Posting to LinkedIn
After generating the content with OpenAI, the final step is to create a post on LinkedIn. Select LinkedIn as the action application and choose ‘Create Simple Text’ as the action event.
Authorize the connection between LinkedIn and Pabbly Connect, then map the generated content to the post field. Finally, set the visibility of the post to Pabbly and send the test request.
Select LinkedIn as the action application. Authorize the connection with your LinkedIn account. Map the generated content to the post field. Set visibility to Pabbly and send the request.
This process ensures that every milestone achievement is automatically posted on LinkedIn, showcasing your company’s growth effectively through Pabbly Connect.
Using Pabbly Connect, you can automate the process of generating LinkedIn posts from company milestones efficiently. This integration with Google Sheets and OpenAI allows for seamless updates to your professional network, saving time and enhancing visibility.
