Learn how to generate lesson plans for teachers using Pabbly Connect with Google Sheets, Google Docs, and an AI agent. Follow this detailed tutorial for step-by-step guidance.
1. Accessing Pabbly Connect for Lesson Plan Generation
To begin generating lesson plans for teachers, access Pabbly Connect by visiting the official website. As a manager in an edtech company, using Pabbly Connect streamlines the process of creating structured lesson plans.
Once on the Pabbly Connect website, you can either sign in if you are an existing user or sign up for a free account. Signing up provides access to 100 free tasks each month, which is beneficial for managing multiple lesson plans.
After signing into Pabbly Connect, navigate to the dashboard and click on the ‘Create Workflow’ button located in the top right corner. This initiates the workflow setup process for generating lesson plans.
In the dialog box that appears, name your workflow, such as ‘AI Agent to Generate Lesson Plans for Teachers’. Select a folder to save this workflow, ensuring it is organized within your Pabbly Connect account.
  • Select an existing folder or create a new one.
  • Click on the ‘Create’ button to finalize the workflow.
After creating the workflow, you will see two main windows: the trigger window and the action window. This setup is essential for establishing the automation process.
The next step involves setting up the trigger for your workflow. Select Google Sheets as your trigger application, as this is where the lesson plan details will be recorded. Choose the trigger event as ‘New or Updated Spreadsheet Row’ to capture any new entries.
Upon selecting the trigger application, Pabbly Connect provides a webhook URL. Copy this URL to connect your Google Sheets to Pabbly Connect. This connection enables automatic updates whenever new data is entered in the spreadsheet.
  • Open your Google Sheets and go to Extensions > Add-ons > Get Add-ons.
  • Search for and install Pabbly Connect Webhooks.
After installation, refresh your Google Sheets and set up the initial configuration by pasting the webhook URL and selecting the trigger column. This column will determine when the data is sent to Pabbly Connect.
4. Generating AI Content with Pabbly Connect
With the trigger set up, the next phase is to configure the action step using OpenAI as the action application. By selecting OpenAI, you can generate structured lesson plans based on the data captured from Google Sheets.
You’ll need to connect OpenAI to Pabbly Connect by adding a new connection. This process requires an API token, which you can generate from your OpenAI account. After entering the token, select the AI model you wish to use, such as GPT-4 Mini.
Generate a new API token in your OpenAI account. Paste the token into Pabbly Connect. Set the prompt for generating lesson plans.
Ensure your prompt is specific, detailing the required output fields like lesson title, objectives, and homework. This structured approach helps the AI agent generate relevant content accurately.
5. Updating Google Sheets with Generated Content
Once the AI content is generated, you will want to update your Google Sheets with this information. For this, select Google Sheets again as your action application and choose the ‘Update Row’ action event. using Pabbly Connect
Connect to your Google Sheets account and select the spreadsheet and specific sheet you want to update. Map the generated data from the AI response to the corresponding fields in your Google Sheets. This ensures that the lesson plan details are systematically recorded.
Select the spreadsheet and specific sheet for updates. Map the generated lesson title, objectives, and homework to the appropriate columns. Click ‘Save and Send Test Request’ to finalize the update.
After saving, check your Google Sheets to confirm that the AI-generated content has been successfully added, completing the workflow.
This tutorial demonstrated how to generate lesson plans for teachers using Pabbly Connect and an AI agent. By following these steps, educators can automate the process of creating structured lesson plans efficiently.
Utilizing Pabbly Connect allows for seamless integration between Google Sheets and OpenAI, making lesson planning easier and more organized.
