Learn how to use Pabbly Connect to automate lead generation from TikTok and save data in Stackby effortlessly. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To start the automation process, first, log in to your Pabbly Connect account. This platform serves as the backbone for integrating TikTok lead generation with Stackby, allowing you to automate the data transfer seamlessly.
Once logged in, navigate to your dashboard. Here, you will create a new workflow by clicking the ‘Create Workflow’ button. Name your workflow something descriptive, like ‘Send TikTok Leads to Stackby Database Automatically’. This simple setup will pave the way for a smooth lead generation process.
The next step involves configuring the trigger for your automation. In your newly created workflow, select TikTok as your trigger application. This will be the source of your leads. Choose the event type as ‘New Lead’ to initiate the workflow whenever a lead is generated from your TikTok lead ads.
- Click on ‘Connect’ to establish a connection with TikTok.
- Select ‘Add New Connection’ from the window that appears.
- Log in to your TikTok account and authorize the connection.
Once connected, you will need to select your advertiser ID and the lead generation form you created earlier. This setup ensures that whenever a new lead is captured, it triggers the workflow in Pabbly Connect.
3. Creating a Test Lead
After setting up the trigger, it’s crucial to test the integration. In Pabbly Connect, click on the action panel to create a test lead. Select TikTok again and choose the action event ‘Create Test Lead’. This will help you simulate a lead generation event without needing an active ad campaign.
Connect to TikTok once more, authorize the connection, and select the same advertiser ID and lead generation form. After saving and sending the test request, you will receive test lead data, which will be crucial for ensuring that the automation works correctly.
4. Adding Leads Data to Stackby
Now that you have a test lead data, it’s time to send this information to Stackby. In your workflow, click the plus icon to add another action step. Search for Stackby and select it as your action application. Choose the ‘Create Row’ action event to insert the lead data into your Stackby database. using Pabbly Connect
- Connect to Stackby using your API key, which you can find in your Stackby account settings.
- Select the workspace, stack, and table where you want to store the lead data.
- Map the fields from the test lead data to the corresponding columns in Stackby.
This mapping ensures that when a real lead is generated, the data will automatically populate in your Stackby database, streamlining your lead management process.
5. Finalizing Your Automation
With the test data mapped, click on ‘Save and Send Test Request’ to finalize the integration. You should see a confirmation that the data has been sent successfully to Stackby. Check your Stackby dashboard to confirm that the test lead appears in your designated table.
Once set up, this automation will run continuously, capturing leads from TikTok and adding them to Stackby without any manual effort. You only need to configure this once, and Pabbly Connect will handle the rest, making your lead generation process efficient and effective.
Using Pabbly Connect, you can effortlessly automate the process of generating leads from TikTok and adding them to Stackby. This integration not only saves time but also enhances your lead management strategy significantly. Start leveraging this automation today to boost your business efficiency.
