Learn how to fetch videos from YouTube and automatically post them inside Blogger using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To start fetching videos from YouTube and posting them inside Blogger, first, you need to access Pabbly Connect. This platform serves as the central integration tool that connects various applications seamlessly.
Log in to your Pabbly Connect account. If you don’t have one, create a new account by signing up. Once logged in, you will be directed to the dashboard where you can create a new workflow for your integration.
After accessing Pabbly Connect, the next step is to create a workflow. Click on the ‘Create Workflow’ button on your dashboard. This will allow you to set up the integration between YouTube and Blogger.
In the workflow settings, you need to name your workflow. For example, you can name it ‘Fetch YouTube Videos to Blogger’. Then, select YouTube as the trigger application from the dropdown list. This is where you will specify the event that triggers the workflow.
- Click on ‘YouTube’ from the applications list.
- Choose the trigger event as ‘New Video in Channel’.
- Connect your YouTube account to Pabbly Connect.
Once you have set the trigger, click on ‘Save and Continue’ to proceed to the next step of the integration.
3. Configure YouTube Settings in Pabbly Connect
Now that you have set up the trigger, it’s time to configure the YouTube settings. In this section, Pabbly Connect will guide you through connecting your YouTube account.
After connecting your YouTube account, you will need to select the specific channel from which you want to fetch videos. Ensure that the channel is Pabbly and has the necessary permissions enabled.
- Select the YouTube channel from which to fetch videos.
- Test the connection to ensure it is working correctly.
Once the settings are configured, click on ‘Save & Continue’ to move to the next step, which involves integrating with Blogger.
4. Connect Pabbly Connect to Blogger
With YouTube configured, it’s time to connect Pabbly Connect to Blogger. This will allow you to post the fetched videos directly into your Blogger account.
In the next step, select Blogger as the action application. You will need to connect your Blogger account by authorizing Pabbly Connect to access your Blogger account. This step is crucial for enabling the posting of videos.
Choose ‘Blogger’ as the action application. Select the action event as ‘Create a Post’. Authorize your Blogger account to allow Pabbly Connect to post videos.
After successful authorization, click on ‘Save & Continue’ to finalize the connection.
5. Test and Activate Your Workflow
Now that you have set up the integration between YouTube and Blogger via Pabbly Connect, it’s important to test the workflow to ensure everything is functioning as expected.
Click on the ‘Test Workflow’ button. This will fetch a sample video from your YouTube channel and attempt to create a post in Blogger. Check your Blogger account to see if the post has been successfully created with the video embedded.
If the test is successful, activate your workflow by clicking on the ‘Activate’ button. This will ensure that every time a new video is uploaded to your YouTube channel, it will automatically be posted to your Blogger account without any manual intervention.
Using Pabbly Connect, you can easily automate the process of fetching videos from your YouTube channel and posting them inside Blogger. This integration saves time and ensures your content is consistently updated across platforms. Follow these steps to streamline your video posting process effectively.
