Learn how to enroll students in Teachable automatically when a course is purchased on Digistore24 using Pabbly Connect. Step-by-step tutorial included. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To initiate the process of enrolling students in Teachable when a course is purchased on Digistore24, you first need to access Pabbly Connect. Start by visiting the Pabbly website, where you can sign up for a free account or log in if you already have one.
Once logged in, navigate to your dashboard and click on ‘Create Workflow’. Here, you can name your workflow, for instance, ‘Digistore24 to Teachable’. This will set the stage for the automation process.
In this section, you will set up the trigger in Pabbly Connect to connect Digistore24. In the trigger window, select Digistore24 as the application and choose the ‘New Order’ event as the trigger.
- Select ‘New Order’ as the trigger event.
- Paste this URL into your Digistore24 account under the settings for webhooks.
After saving the webhook in Digistore24, you will need to make a test purchase to capture the data in Pabbly Connect. This data will include customer details necessary for enrolling them in Teachable.
3. Connecting Digistore24 to Pabbly Connect
Next, you will finalize the connection between Digistore24 and Pabbly Connect. On the Digistore24 dashboard, go to ‘Settings’ and then ‘Integrations’. Here, create a new connection and name it appropriately, such as ‘Pabbly Integration’.
Ensure to select the appropriate product for which you want to receive notifications and set the event to only capture payment notifications. Once you paste the webhook URL from Pabbly Connect, save the integration and confirm that it is active.
4. Enrolling Students in Teachable
Now that you have set up Digistore24, the next step is to enroll the customer in Teachable using Pabbly Connect. In the action window, select Teachable as the application and choose the ‘Enroll User in a Course’ action event.
- Connect your Teachable account by entering the required credentials.
- Select the course you want to enroll the student in.
- Map the customer’s email and name from the Digistore24 trigger response.
Once you have filled in all required fields, click on ‘Save and Send Test Request’ to check if the student has been successfully enrolled in the course.
After setting up both the trigger and action, it’s crucial to test the entire workflow in Pabbly Connect. Make another test purchase in Digistore24, following the same procedure as before.
Once the purchase is made, return to Pabbly Connect and check if the student is enrolled in Teachable. You can verify this by checking the students list in your Teachable course dashboard.
If the test is successful, you will see that the customer has been added to your course automatically, confirming that your automation is functioning correctly. This seamless integration saves time and effort in managing student enrollments.
Using Pabbly Connect, you can easily automate the enrollment of students in Teachable whenever a course is purchased on Digistore24. This integration not only streamlines the process but also enhances the efficiency of your online education business.
