To start automating your workflow, first, access Pabbly Connect by visiting the official site. Once there, you can either sign up for a free account or log in if you are an existing user. This platform is essential for integrating various applications seamlessly.
After logging in, navigate to the dashboard where you can manage all your workflows. Click on the “Create Workflow” button to initiate the setup process. This step is crucial as it sets the stage for the integration between Google Forms, WhatsApp, and Gmail.
2. Setting Up Google Forms as a Trigger
In this section, we will set Google Forms as the trigger application in Pabbly Connect. This means that whenever a new form submission occurs, it will initiate the automation process. Start by selecting Google Forms as your trigger app.
- Select “New Response Received” as the trigger event.
- Click on the “Connect” button to establish the connection.
- Copy the generated webhook URL to link it with your Google Form.
Next, go to your Google Forms account and open the form you want to use. Ensure you publish the form to start receiving responses. Once published, fill out the form to test if the integration works correctly. This step confirms that your Google Forms are effectively linked to Pabbly Connect.
3. Sending WhatsApp Messages via Pabbly Connect
After successfully setting up Google Forms, the next step is to send WhatsApp messages using Pabbly Connect. This action takes place after a form is submitted. Select “Pabbly Chatflow” as your action application.
- Choose “Send Text Message” as the action event.
- Click on the “Connect” button and create a new connection by entering your API token.
- Map the recipient’s mobile number and customize the message content.
This mapping is crucial as it ensures that each user receives a personalized message based on their form submission. Once everything is set up, test the integration to confirm that messages are sent correctly through WhatsApp.
4. Sending Confirmation Emails via Gmail
The final step in your automation process is to send confirmation emails using Gmail through Pabbly Connect. This ensures that users receive all necessary information after submitting the form.
Begin by selecting Gmail as your action application and choose “Send Email” as the action event. Establish a new connection by signing in to your Google account and granting Pabbly Connect the necessary permissions.
- Map the recipient’s email address from the Google Forms response.
- Customize the email subject and body to include personalized details.
- Select the email content type, ideally HTML for better formatting.
After configuring these settings, test the email functionality to ensure that users receive their confirmation emails promptly after form submission.
5. Conclusion: Automate Your Business with Pabbly Connect
In conclusion, using Pabbly Connect to automate the integration of Google Forms with WhatsApp and Gmail enhances your business efficiency. By implementing this workflow, you ensure that users receive immediate responses, increasing the likelihood of conversion.
Automating these processes not only saves time but also improves customer satisfaction. Start using Pabbly Connect today to streamline your business operations and enhance user engagement.
