Learn how to create a Kit subscriber automatically on successful Razorpay payments using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
To create a Kit subscriber on successful Razorpay payment, the first step is accessing Pabbly Connect. This platform enables seamless integration between Razorpay and Kit.
Open your web browser and navigate to Pabbly.com/connect. If you don’t have an account, click on the ‘Sign Up for Free’ button. Existing users can simply log in. Once logged in, you will be directed to the Pabbly Connect dashboard, where you can create a new workflow.
In your Pabbly Connect dashboard, click on the ‘Create Workflow’ button to initiate a new automation process. Name your workflow something descriptive, such as ‘Create Kit Subscriber on Successful Razorpay Payment,’ and select the appropriate folder for saving it. using Pabbly Connect
  • You will see two boxes: Trigger and Action.
  • Set up the trigger by selecting Razorpay as the application.
Setting the trigger is essential as it tells Pabbly Connect what event will initiate the workflow. In this case, select ‘Payment Captured’ as the trigger event to capture successful payments from Razorpay.
3. Connecting Razorpay to Pabbly Connect
After setting up the trigger, you need to connect Razorpay with Pabbly Connect. Copy the provided webhook URL from Pabbly Connect, which acts as a bridge between Razorpay and Pabbly.
  • Log into your Razorpay account.
  • Navigate to Account Settings and find the Webhooks section.
  • Click on ‘Add New Webhook’ and paste the copied URL.
Specify the active event as ‘Payment Captured’ and click on ‘Create Webhook’ to finalize the setup. This will ensure that Razorpay sends payment details to Pabbly Connect whenever a successful transaction occurs.
4. Setting Up Kit Subscriber Action in Pabbly Connect
Now that Razorpay is connected, it’s time to set up the action in Pabbly Connect. Search for Kit in the action application section and select it. Choose ‘Add Subscriber to a Sequence’ as your action event.
To connect Kit with Pabbly, you will need your API key and API secret from your Kit account. Log into Kit, navigate to Account Settings, and under Developer options, you can find these credentials. Copy and paste them into Pabbly Connect to establish the connection.
5. Mapping Details and Testing the Setup
With the connection established, you need to map the details from Razorpay to Kit. This step is crucial as it ensures the correct information is transferred when a payment is captured. using Pabbly Connect
Map fields such as first name, last name, email, and mobile number from the Razorpay response. Select the appropriate sequence in Kit where the subscriber will be added.
Once you have mapped all necessary details, click on ‘Send Test’ to verify that everything is functioning correctly. If successful, you will see a confirmation message, and the subscriber will be added to your Kit account based on the payment details received from Razorpay.
In this tutorial, we explored how to create a Kit subscriber automatically on successful Razorpay payments using Pabbly Connect. By setting up triggers and actions, you can streamline your workflow and enhance customer management efficiently. Automate your processes today with Pabbly Connect!
