1. Accessing Pabbly Connect for Your AI Assistant
To start integrating your AI assistant using Pabbly Connect, first access the platform. If you are a new user, visit the Pabbly website and sign up for a free account. Existing users can simply log in to their dashboard.
Once logged in, navigate to the Pabbly Connect section. This powerful tool allows you to create workflows that connect various applications, including My AI and WhatsApp. Follow these steps to get started:
  • Visit the Pabbly website and sign up or log in.
  • Go to the Pabbly Connect section.
  • Start creating your first workflow.
By using Pabbly Connect, you can seamlessly integrate your AI assistant into your business operations, allowing for automated responses to customer inquiries.
2. Creating Your AI Assistant with Pabbly Chatflow
Next, you will create your AI assistant using Pabbly Chatflow. This involves setting up the assistant to respond to customer queries effectively. Navigate to the AI assistant section within Pabbly Chatflow.
Here, you can select the type of AI agent you want to create. Choose the appropriate settings to ensure that your assistant is tailored to your business needs:
  • Select ‘AI Agent’ as your instruction type.
  • Set the temperature for creativity (0.5 is recommended).
  • Choose the model, like GPT-5 Mini.
Once configured, you can save your settings. This setup allows Pabbly Connect to effectively manage interactions between your AI assistant and customers, ensuring timely responses.
3. Uploading the Knowledge Base for Your AI Assistant
To enhance your AI assistant’s functionality, you will need to upload a knowledge base. This serves as the information source for your assistant to answer queries accurately. In the knowledge source tab, you can upload documents in either TXT or PDF formats.
Follow these steps to upload your knowledge base:
  • Navigate to the knowledge source tab in Pabbly Chatflow.
  • Select the file you wish to upload.
  • Click on the insert button to upload the document.
With the knowledge base in place, Pabbly Connect will empower your AI assistant to provide accurate information to customers, enhancing their experience.
4. Configuring AI Assistant Settings in Pabbly Connect
After uploading your knowledge base, you need to configure specific settings for your AI assistant. This includes setting up header messages, footer texts, and stop keywords. Access the AI assistant settings tab to make these adjustments.
Ensure you set the following configurations:
  • Enter a header message that reflects your brand.
  • Set a footer message for customer reassurance.
  • Specify any stop keywords to manage conversations effectively.
These settings help tailor the customer interaction experience, making it more personal. By using Pabbly Connect, your AI assistant will be able to handle inquiries efficiently while maintaining brand voice and consistency.
5. Enabling Your AI Assistant on WhatsApp
The final step is to enable your AI assistant on WhatsApp through Pabbly Connect. This integration allows your assistant to respond to customer messages directly within the WhatsApp platform, streamlining communication.
To enable this feature, follow these steps:
  • Go to the settings and select inbox settings.
  • Enable AI auto replies for all contacts or specific contact lists.
  • Choose the AI assistant you created to link with WhatsApp.
With these configurations, your AI assistant is live on WhatsApp, ready to assist customers. This integration showcases the power of Pabbly Connect in automating customer interactions, allowing your business to operate more efficiently.
In this tutorial, we explored how to integrate My AI, Pabi, and WhatsApp using Pabbly Connect. By following these steps, you can automate customer interactions and enhance your business efficiency. Start leveraging the power of AI today!
