Learn how to create an AI assistant for your Telegram channel using Pabbly Connect. Step-by-step guide for seamless integration with Facebook and other tools. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
1. Setting Up Pabbly Connect for Your AI Assistant
To create an AI assistant for your Telegram channel, the first step involves accessing Pabbly Connect. You can easily sign up for a free account through the link provided in the description.
Once you log into Pabbly Connect, you will find yourself on the dashboard. From here, click on the ‘Create Workflow’ button. Enter a name for your workflow, such as ‘AI Assistant for Telegram’. Select the folder where you want to save this workflow and click on ‘Create’. This will open a new workflow window where you can set up your automation.
2. Creating a Telegram Bot Using Pabbly Connect
To integrate with Telegram, you need to create a bot. Open Telegram and search for ‘BotFather’. Start a chat with BotFather and send the command ‘/newbot’ to create a new bot. You will be prompted to give your bot a name, for instance, ‘Papon AI Assistant’.
  • Enter a username for your bot, ending with ‘_bot’.
  • Once created, you will receive an API token which you will use to connect your bot to Pabbly Connect.
  • Add this bot as an admin to your Telegram channel.
After adding the bot, refresh your Telegram page to ensure it is listed as an admin. This setup allows the bot to monitor messages in the channel, which Pabbly Connect will use to trigger responses.
3. Connecting the Telegram Bot to Pabbly Connect
Now, return to Pabbly Connect and in the workflow, select the Telegram Bot as the application for the trigger event. Choose the event as ‘Set Webhook/Watch Updates’. Click on connect and select ‘Add New Connection’.
In the connection window, paste the API token you received from BotFather and click on ‘Save’. Once connected, click on ‘Save and Send Test Request’. This action makes Pabbly Connect wait for a message from the Telegram bot.
Send a message in the Telegram channel, tagging your bot. This message will be captured by Pabbly Connect, allowing you to proceed with the next steps to create your AI assistant.
4. Creating the AI Assistant with Pabbly Connect
After the Telegram bot is connected, the next step is to create the AI assistant. In your Pabbly Connect workflow, add a new action step and select ‘AI Assistant by Pabbly’. Choose the action event ‘Create Assistant’.
Connect to your OpenAI account by entering your API key. This key can be generated from your OpenAI dashboard under the API key section. Name your assistant and provide a knowledge base URL, which can be a Google Drive link, ensuring it’s publicly accessible.
  • Enter chatbot instructions that guide how the AI should respond.
  • Select the OpenAI model you wish to use for generating replies.
  • Click on ‘Save and Send Test Request’ to create the assistant.
After this step, you will have a functioning AI assistant integrated with Pabbly Connect, ready to respond to user queries in the Telegram channel.
5. Sending Replies Back to Telegram Using Pabbly Connect
With the AI assistant set up, the final step is to send responses back to Telegram. Add another action step in your Pabbly Connect workflow and select ‘Telegram Bot’ again. This time, choose the action event ‘Send a Text Message or Reply’.
Map the chat ID from the previous steps and enter the reply text that the AI assistant generated. You can also specify whether to disable notifications or web page previews. Finally, click on ‘Save and Send Test Request’ to send the reply back to the Telegram channel.
Once this is set up, any message tagged to your bot in the Telegram channel will trigger the AI assistant, which will generate a response and post it back in the channel, all facilitated through Pabbly Connect.
In conclusion, creating an AI assistant for your Telegram channel using Pabbly Connect is a straightforward process. By following these steps, you can automate responses to user inquiries efficiently, enhancing engagement in your channel. This integration not only saves time but also provides instant support to your users.
