To start integrating WhatsApp with Pabbly Connect, first navigate to the Pabbly Connect website. This powerful tool allows you to automate workflows seamlessly.
For new users, sign up for a free account at Pabbly Connect. Existing users can simply log in. Once logged in, you’ll be directed to the workflow page, where you can create automation.
2. Setting Up the Trigger with Facebook Lead Ads
The first step in your automation is to set up a trigger using Facebook Lead Ads. This trigger will initiate the workflow whenever a new lead is captured.
- Click the ‘Add Trigger’ button in Pabbly Connect.
- Select ‘Facebook Lead Ads’ as your trigger application.
- Choose ‘New Lead’ as the event.
After selecting the trigger, connect your Facebook account by following the prompts. Once connected, select the specific page and form to fetch leads.
3. Adding Lead Data to Google Sheets
After capturing a lead, the next step is to add this data to Google Sheets. This integration ensures that all your leads are organized in one place.
In Pabbly Connect, select Google Sheets as your action app and choose ‘Add New Row’ as the event. Connect your Google account and select the spreadsheet where you want to store the data.
- Map the fields from the Facebook lead form to the corresponding columns in Google Sheets.
- Ensure that the data is dynamically mapped to accommodate future leads.
Once the mapping is complete, test the action to ensure that the lead data is being added correctly to your Google Sheets.
4. Sending WhatsApp Messages to Leads
Next, you will set up an action to send a WhatsApp message to the newly captured lead. This step enhances communication and improves customer engagement.
In Pabbly Connect, select the WhatsApp Cloud API as your action app and choose ‘Send Text Message’ as the event. You will need to configure the API settings by entering your access token and other required details.
- Map the lead’s phone number to the recipient field.
- Craft a personalized message that includes the lead’s details.
Once configured, send a test message to confirm that everything is working as intended. This integration ensures that leads receive immediate acknowledgment.
5. Notifying Your Team on Slack
The final step in this automation is to notify your team about the new lead via Slack. This keeps everyone informed and ready to take action.
In Pabbly Connect, select Slack as your action app and choose ‘Send Channel Message’ as the event. Connect your Slack account and select the channel where notifications will be sent.
- Enter a message that includes the details of the new lead.
- Map the lead’s information to the message for personalized notifications.
After setting up the message, send a test request to ensure that your team receives the notification in Slack. This integration streamlines communication and enhances team collaboration.
By following this tutorial, you can effectively automate your business workflow using Pabbly Connect. Integrating WhatsApp, Google Sheets, and Slack not only saves time but also enhances communication, allowing you to focus on growing your business.
