1. Access Pabbly Connect for Automation
To start automating your social media posts, access Pabbly Connect by visiting pabby.com/connect. Here, you will find options to sign in or sign up for free. If you’re new, click on “Sign Up Free” to create an account and receive 300 tasks monthly.
Once you are logged in, navigate to the Pabbly Connect dashboard. Here, you can create a new workflow by selecting either “Create from Scratch” or using the AI workflow builder. Choose the method that suits your needs best and proceed to set up your automation.
In Pabbly Connect, creating a workflow is essential for automation. Click on “Create New Workflow” and name it something relevant, like “Social Media Automation with OpenAI.” Choose the desired folder for organization.
Next, you will set up a trigger. Choose “Google Sheets” as the trigger app and select “New or Updated Spreadsheet Row” as the event. This will allow Pabbly Connect to monitor your Google Sheets for any new entries, which will initiate the automation.
- Select Google Sheets as the trigger app.
- Choose “New or Updated Spreadsheet Row” as the trigger event.
After setting the trigger, click on “Create” to finalize your workflow setup. This is the first step in connecting your Google Sheets with Pabbly Connect.
3. Connect Google Sheets with Pabbly Connect
To link your Google Sheets with Pabbly Connect, you will need a webhook URL. Once the trigger is set, Pabbly Connect will provide you with a webhook URL. Copy this URL and open your Google Sheets.
In your Google Sheets, install the Pabbly Connect Webhooks add-on. Go to “Extensions” > “Add-ons” > “Get Add-ons” and search for “Pabbly Connect Webhooks”. Install the add-on and refresh your Google Sheets to activate it. After refreshing, set up the webhook by going to “Extensions” > “Pabbly Connect Webhooks” > “Initial Setup”.
- Paste the copied webhook URL into the setup.
- Set the trigger column to the last column of your data.
- Click “Submit” to complete the setup.
After submitting, test the connection by adding a new row in your Google Sheets. This will send data to Pabbly Connect, confirming that the integration is successful.
4. Generate Content Using OpenAI in Pabbly Connect
After successfully connecting Google Sheets to Pabbly Connect, the next step is to generate content using OpenAI. Add an action step in your workflow and select OpenAI as the application. Choose “Create Completion” as the event to generate content based on the data received from Google Sheets.
To connect OpenAI, you will need an API key. Click the link provided in Pabbly Connect to access your OpenAI account and create a new secret key. Copy this key and paste it into Pabbly Connect to establish the connection.
- Access your OpenAI account to generate an API key.
- Map the data fields from Google Sheets to the OpenAI prompt.
- Click “Save and Send” to generate the content.
Once you receive a successful response from OpenAI, the content is ready for posting on social media platforms.
5. Share Generated Content on Social Media Platforms
The final step is to share the generated content on your social media accounts using Pabbly Connect. Add another action step and select Facebook Pages as the application. Choose “Share Page Post” as the event to publish the content on your Facebook page.
Connect your Facebook account and select the page where you want to post. Map the content generated by OpenAI to the message field in the Facebook post. Repeat the process for LinkedIn by selecting LinkedIn as the action application and mapping the same content to the post.
- Select Facebook Pages and LinkedIn for posting.
- Map the OpenAI generated content to the post message.
- Click “Save and Send” to publish your posts.
After executing these steps, you will see the new posts on both your Facebook and LinkedIn accounts, showcasing the content generated by OpenAI through the seamless integration facilitated by Pabbly Connect.
In this tutorial, we explored how to use Pabbly Connect to automate social media posting by integrating Google Sheets and OpenAI. By following these steps, you can efficiently manage your social media content and streamline your marketing efforts.
