Learn how to automatically share your Blogger posts to Twitter using Pabbly Connect without any coding. Follow our step-by-step tutorial for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Accessing Pabbly Connect for Blogger to Twitter Integration
To start sharing your Blogger posts automatically on Twitter, access Pabbly Connect. This platform allows seamless integration between various applications, including Blogger and Twitter. Begin by creating a free account on Pabbly Connect if you haven’t done so already.
Once logged in, navigate to the dashboard where you can set up your integration. Pabbly Connect simplifies the process of connecting your Blogger account to Twitter, eliminating the need for any coding skills. You will be guided through each step of the integration process.
2. Setting Up the Trigger for New Blogger Posts
In this step, you will configure Pabbly Connect to detect new posts on your Blogger account. Select the option to create a new workflow, and choose Blogger as the trigger application. You will then set the trigger event to ‘New Post’ which will notify Pabbly Connect whenever you publish a new post. using Pabbly Connect
- Select ‘Blogger’ from the list of applications.
- Choose ‘New Post’ as the trigger event.
- Connect your Blogger account by following the prompts.
- Test the trigger to ensure it captures new posts correctly.
Once the trigger is set, Pabbly Connect will monitor your Blogger account for any new posts. This setup is crucial for ensuring that your content is shared on Twitter automatically.
3. Configuring Twitter as the Action Application
Next, you will set up Twitter as the action application in Pabbly Connect. This is where your Blogger posts will be shared automatically. Select Twitter from the list of applications and choose the action event as ‘Create Tweet’. using Pabbly Connect
- Choose ‘Twitter’ as the action application.
- Select ‘Create Tweet’ as the action event.
- Connect your Twitter account to Pabbly Connect.
- Map the fields from Blogger to Twitter, including the title and URL of the post.
By completing this setup, you ensure that every new post on your Blogger account is automatically tweeted, keeping your Twitter followers updated with your latest content.
4. Testing the Integration Between Blogger and Twitter
After configuring both applications, it’s essential to test the integration. Pabbly Connect allows you to send test data through the workflow to ensure everything works smoothly. Click on the test button to send a sample post from Blogger to Twitter. using Pabbly Connect
Once the test is complete, check your Twitter account to see if the tweet has been posted successfully. This step is vital to confirm that Pabbly Connect is functioning correctly and that your Blogger posts are being shared as intended.
5. Finalizing and Activating Your Workflow
Once you have tested the integration successfully, it’s time to finalize your workflow. Give your workflow a name that reflects its purpose, such as ‘Blogger to Twitter Integration’. After naming, activate the workflow by toggling the switch on. using Pabbly Connect
Now, every time you publish a new post on your Blogger account, Pabbly Connect will automatically share it on your Twitter account without any coding required. This automation saves you time and ensures your audience is always informed about your latest content.
In this tutorial, we explored how to use Pabbly Connect to automatically share your Blogger posts on Twitter. By following the steps outlined, you can streamline your social media presence effortlessly. Enjoy the benefits of automation and keep your audience engaged with minimal effort.
