Learn how to integrate Blogger and Discord using Pabbly Connect to automatically share posts via Bit.ly shortened links. Follow our step-by-step tutorial! Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Accessing Pabbly Connect for Blogger and Discord Integration
To start the integration process, you need to access Pabbly Connect. This platform will be crucial in automating the sharing of your Blogger posts to Discord. Begin by visiting the Pabbly website and navigating to the Pabbly Connect section.
Once there, you can sign up for a free account or log in if you already have one. After logging in, you will be directed to the Pabbly Connect dashboard where you can create a new workflow to facilitate the integration between Blogger and Discord.
In this step, you will create a new workflow for integrating Blogger and Discord using Pabbly Connect. Click on the plus sign to create a workflow and name it something like ‘Blogger to Discord Integration’. This name can be customized based on your preference.
After naming your workflow, you will see a trigger and action section. Pabbly Connect operates on a trigger-action model. The trigger will be set to ‘New Post Added’ from Google Blogger, which captures new posts when they are published.
- Click on the trigger window and select Google Blogger.
- Choose the trigger event as ‘New Post Added’.
- Connect your Google Blogger account to Pabbly Connect.
After setting up the trigger, you will need to select the blog ID from your Blogger account to ensure the correct blog is monitored for new posts. This setup ensures that every time a new post is published, Pabbly Connect captures the necessary details for further processing.
3. Shortening Blogger Post Links Using Bit.ly
Now that Pabbly Connect is capturing the new posts from Blogger, the next step is to shorten the Blogger post links using Bit.ly. This is essential for sharing clean and concise links on Discord. In the action section of Pabbly Connect, select Bit.ly as the application. using Pabbly Connect
The action event you want to choose is ‘Shorten Link’. After connecting your Bit.ly account to Pabbly Connect, you will map the long URL from Blogger to the Bit.ly action. This allows Pabbly Connect to automatically generate a shortened version of your Blogger post link.
- Select the action event as ‘Shorten Link’.
- Map the long URL from the Blogger trigger into the Bit.ly action.
- Click on save and send test request to generate the shortened URL.
Once the shortened URL is generated, you can proceed to the next step of sharing this link on your Discord channel.
4. Sharing Blogger Post Links on Discord
With the shortened link ready, you can now share it on your Discord channel using Pabbly Connect. In the action step, select Discord as the application and choose the action event ‘Send Channel Message’. This allows you to send a message containing the shortened link to your desired Discord channel.
Before you can send messages, you must set up a webhook URL from your Discord channel. This URL is needed for Pabbly Connect to post messages directly to your channel. After retrieving the webhook URL, paste it into Pabbly Connect and format your message to include the shortened link.
Select the action event as ‘Send Channel Message’. Paste the webhook URL from your Discord channel. Compose the message including the shortened link.
Once you have set up the message, click on save and send test request to ensure everything is working correctly. You should see the message appear in your Discord channel shortly after a new post is published on Blogger.
5. Verifying the Integration between Blogger and Discord
After completing the setup, it’s essential to verify that the integration between Blogger and Discord is functioning correctly through Pabbly Connect. To test this, create a new post in your Blogger account. This will trigger the workflow you set up in Pabbly Connect.
Once the post is published, check your Discord channel to see if the message with the shortened link appears. If everything is set up correctly, you should see a notification in Discord about the new post, complete with the shortened link for easy access.
If the message does not appear immediately, remember that the trigger is polling based, so it may take a few minutes for the data to be fetched. Be patient, and refresh your Discord channel to see the results.
This tutorial demonstrated how to use Pabbly Connect to automate the sharing of Blogger posts on Discord with Bit.ly shortened links. By following these steps, you can ensure that every new post on Blogger is shared seamlessly in your Discord channel, enhancing engagement and visibility.
Using Pabbly Connect simplifies the process of integrating multiple applications, allowing you to focus on creating content while automating your workflow effectively.
