Learn how to automatically share Instagram posts on LinkedIn using Pabbly Connect. Follow this detailed tutorial for seamless integration. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
1. Accessing Pabbly Connect to Start the Integration
To automatically share Instagram posts on LinkedIn, you first need to access Pabbly Connect. Start by searching for Pabbly.com in your browser and navigate to the Pabbly Connect homepage.
Once there, you will see options to sign in or sign up. If you are a new user, click on ‘Sign Up Free’ to create an account. Existing users can simply log in. After signing in, you will be directed to the dashboard of Pabbly Connect, where you can create a new workflow for your automation.
After accessing your Pabbly Connect dashboard, the next step is to create a new workflow. Click on the ‘Create New Workflow’ button. This will open a new window where you can name your workflow, such as ‘Automatically Share Instagram Posts on LinkedIn.’ This naming is essential for easy identification later.
- You will see two main sections: Trigger and Action.
- Select Instagram as your Trigger application.
Now, choose the event as ‘New Media Posted’ in your Instagram account. This step is crucial as it sets up the trigger that will initiate the automation whenever you post something new on Instagram.
3. Connecting Instagram and LinkedIn through Pabbly Connect
The next step involves connecting your Instagram account to Pabbly Connect. Click on ‘Connect’ and select the option to create a new connection. You will be prompted to log into your Instagram account if you haven’t already done so.
Once connected, you need to select the specific Instagram account you want to use. After selecting your account, click on ‘Save and Send Test Request’ to confirm the connection. At this point, Pabbly Connect will fetch the latest post details from your Instagram account.
4. Adding Action Steps to Share on LinkedIn
Now it’s time to set up the action step to share the Instagram post on LinkedIn. In the Action section of Pabbly Connect, select LinkedIn as your action application. Choose the event as ‘Share Text with Image’ to ensure that the post is shared correctly.
- Click on ‘Connect’ and create a new connection for LinkedIn.
- Log in to your LinkedIn account when prompted.
- Select the Author and the relevant group for sharing the post.
After establishing the connection, you will need to map the data fields from your Instagram post to LinkedIn. This includes the image URL and the caption from your Instagram post. By doing this, you ensure that the content shared on LinkedIn mirrors your Instagram post.
With all connections established, it’s time to finalize the integration. Click on ‘Save and Send Test Request’ to check if everything is working as intended. Pabbly Connect will send a test post to your LinkedIn account using the mapped data from Instagram.
Once you receive a successful response, you can check your LinkedIn profile to see if the post appears as expected. This confirms that your automation is set up correctly and working seamlessly. Now, every time you post on Instagram, it will automatically share on LinkedIn as well!
In this tutorial, we explored how to automatically share Instagram posts on LinkedIn using Pabbly Connect. By following these steps, you can streamline your social media management and ensure consistent posting across platforms. Enjoy the benefits of automation!
