Learn how to automatically share your Blogger posts to Medium using Pabbly Connect. Follow this step-by-step guide for seamless integration. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To automatically share Blogger posts to Medium, you first need to access Pabbly Connect. This powerful integration platform allows you to connect various applications seamlessly. Start by visiting the Pabbly Connect website and signing in or creating a new account if you are a new user.
Once logged in, you will be directed to the Pabbly Connect dashboard. Here, you can begin creating your automation workflow. For this integration, we will connect Google Blogger and Medium through Pabbly Connect, allowing for automatic sharing of posts.
2. Creating an Automation Workflow in Pabbly Connect
After accessing your Pabbly Connect dashboard, you can start by creating a new workflow. Click on the ‘Create Workflow’ button and give your automation a name, such as ‘Automatically Share Blogger Posts to Medium’. This title helps you identify the workflow easily. using Pabbly Connect
- Select Google Blogger as the trigger application.
- Choose the trigger event as ‘New Post’ when a new post is published.
- Connect your Google Blogger account by signing in and granting access.
After successfully connecting your Blogger account, select the specific blog and set the status to ‘Live’. This ensures that only published posts are shared automatically to Medium. Now, you are ready to proceed to the next step in Pabbly Connect.
3. Fetching Blogger Post Details with Pabbly Connect
Once the Google Blogger trigger is set, you can test the connection to ensure it is working correctly. Create a new post in your Blogger account, and then return to Pabbly Connect. Click on the ‘Fetch Data’ button to retrieve the latest post details.
During this step, Pabbly Connect will capture essential information like the post title, content, and URL. This data will be used to create a corresponding post on Medium. It’s crucial to ensure that the formatting, including HTML tags, is preserved during this process.
4. Connecting Medium to Pabbly Connect
Now that you have fetched the Blogger post details, the next step is to connect Medium to Pabbly Connect. Select Medium as the action application and choose the action event as ‘Create Post’. This action will allow Pabbly Connect to publish the fetched Blogger post on Medium.
- Click on ‘Connect’ and add a new connection to Medium.
- Provide the integration token from your Medium account to authorize the connection.
- Map the post title and content from the previous step to the respective fields in Medium.
After mapping the fields, click on the ‘Save’ button to finalize the connection. This allows Pabbly Connect to automatically publish your Blogger posts to Medium whenever a new post is created.
5. Conclusion: Automate Sharing with Pabbly Connect
In conclusion, using Pabbly Connect to automatically share your Blogger posts to Medium is an efficient way to streamline your blogging process. By following the steps outlined in this tutorial, you can set up an automation that saves time and ensures your content reaches a broader audience.
Now, every time you publish a new post on Blogger, it will automatically appear on Medium, thanks to the seamless integration provided by Pabbly Connect. Start automating your blogging today and enjoy the benefits of increased visibility and engagement!
