Learn how to automatically reblog your Blogger posts on Tumblr using Pabbly Connect with this step-by-step tutorial. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Setting Up Pabbly Connect for Blogger to Tumblr Automation
To start reblogging your Blogger posts on Tumblr automatically, the first step is to access Pabbly Connect. You can create a free account on Pabbly Connect, which allows you to set up automation workflows easily without any coding skills.
After logging into your Pabbly Connect account, navigate to the dashboard. Click on the ‘Create Workflow’ button to initiate the setup. You can name your workflow something like ‘Google Blogger to Tumblr Automation’ for easy identification.
2. Setting the Trigger with Google Blogger
The next step involves setting up the trigger in Pabbly Connect. Select ‘Blogger’ as your trigger application. The trigger event you need to choose is ‘New Post Added,’ which will activate the automation whenever a new blog post is published on your Blogger account.
- Choose ‘Blogger’ as the trigger application.
- Select the trigger event ‘New Post Added’.
- Connect your Google account to allow Pabbly Connect to access your Blogger data.
After connecting, select the specific blog from which you want to fetch posts. You can choose to share only live posts or include drafts based on your preference.
3. Transforming Data to Remove HTML Tags
Once the trigger is set up, the next step in Pabbly Connect involves processing the data. You will need to add a ‘Data Transformer’ action to strip out any HTML tags from the content of your blog post. This step ensures that the text is clean and ready for Tumblr.
- Select ‘Data Transformer’ as the action application.
- Choose the action event ‘Strip HTML Tags’.
- Map the content field from the Blogger step to remove HTML.
After setting this up, click on ‘Save and Send Test Request’ to verify that the content is being processed correctly. You should receive plain text without any HTML tags, making it suitable for Tumblr.
4. Posting the Content to Tumblr
Now that you have the clean content ready, the next step is to post it to Tumblr using Pabbly Connect. Add another action step and select ‘Tumblr’ as the application. The action event should be set to ‘Create Link Post’.
Choose ‘Tumblr’ as the action application. Select the action event ‘Create Link Post’. Connect your Tumblr account to allow Pabbly Connect to post on your behalf.
Map the necessary fields such as link title, link address, description, and thumbnail from the previous steps. Ensure that all required fields are filled before testing the connection.
5. Finalizing the Automation Workflow
After setting up the action to post on Tumblr, you can finalize your automation in Pabbly Connect. Click on ‘Save and Send Test Request’ to check if the post appears on your Tumblr feed as expected. You should see a new post with the title, image, and description from your Blogger post.
Once confirmed, your workflow is set up! This means that every time you publish a new post on Blogger, it will automatically reblog on Tumblr without any manual effort. You can monitor your automation from the Pabbly Connect dashboard to ensure everything runs smoothly.
In this tutorial, we explored how to use Pabbly Connect to automate the reblogging of your Blogger posts on Tumblr. By following these steps, you can effortlessly share your content across platforms, saving time and increasing your audience reach.
