Learn how to automatically post on Facebook and LinkedIn together using Pabbly Connect with this step-by-step tutorial. Simplify your social media sharing today! Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Access Pabbly Connect for Automation
To start automating your social media posts, you need to access Pabbly Connect. Open your browser and go to Pabbly.com/connect. Here, you will find options to sign in or sign up for free. If you’re new, select ‘Sign Up Free’ to get 100 free tasks per month.
After signing in, you will see the Pabbly Apps window. Click on the ‘Access Now’ button under Pabbly Connect to open the dashboard. This is where you will create your workflow to connect Facebook and LinkedIn automatically.
Once on the dashboard of Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button. You will be prompted to choose between the new beta version and the classic version. For this tutorial, select the beta version for a more modern experience.
In the dialog box that appears, name your workflow ‘Post on Facebook and LinkedIn Together Automatically’. Choose a folder to save your workflow. You can create a new folder if needed. After naming and selecting your folder, click on the ‘Create’ button to proceed.
- Select the Beta Version for a modern experience.
- Choose a folder to organize your workflows.
This setup prepares you for the next steps where you will define the trigger and action for your automation process using Pabbly Connect.
3. Set Up the Trigger for Facebook Post
With your workflow created, it’s time to set up the trigger. Click on the ‘Add Trigger’ button and select ‘Facebook Pages’ as the app. Choose ‘New Post’ as the event. Click on ‘Connect’ to build a new connection.
If your Facebook account is already connected to Pabbly Connect, you can select the existing connection. If not, click ‘Add a New Connection’ and log in to your Facebook account. Once connected, select the specific Facebook page you want to monitor for new posts and click ‘Save and Send Test Request’.
- Choose ‘Facebook Pages’ as the trigger app.
- Select ‘New Post’ as the event.
- Connect to your Facebook account for seamless integration.
This step ensures that every time you post on Facebook, Pabbly Connect will be ready to trigger the next action.
4. Configure the Action to Post on LinkedIn
Now that your trigger is set, you will add an action step. Select ‘LinkedIn’ as the action application and choose ‘Share a Text with Image’ as the app event. Click on ‘Connect’ to establish the connection with your LinkedIn account.
Once connected, you need to map the data from the Facebook post to the LinkedIn post. For the author, it will automatically be selected. Map the image file URL and text content from the Facebook post response. Finally, set the visibility to ‘Pabbly’ and click ‘Save and Send Request’.
Select ‘LinkedIn’ as the action app. Choose ‘Share a Text with Image’ as the event. Map the data to ensure the LinkedIn post mirrors the Facebook post.
This step completes the automation setup, allowing Pabbly Connect to share your Facebook posts directly on LinkedIn.
5. Test and Finalize the Integration
With the workflow configured, it’s essential to test the integration. Create a new post on your Facebook page with a caption and an image. After posting, check your LinkedIn account to see if the post appears.
If everything is set up correctly, you should see the same caption and image on LinkedIn shortly after posting on Facebook. This successful test confirms that Pabbly Connect is functioning as intended, automating your social media sharing.
In conclusion, using Pabbly Connect for this integration not only saves time but also ensures your content reaches a wider audience effortlessly. This automation allows you to focus on creating content while the technical aspects are handled seamlessly.
In this tutorial, we explored how to automatically post on Facebook and LinkedIn together using Pabbly Connect. By following these steps, you can streamline your social media management and enhance your online presence.
