Learn how to automatically post new products to Twitter from BigCommerce using Pabbly Connect. Follow this detailed step-by-step tutorial for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Introduction to Pabbly Connect for BigCommerce and Twitter Integration
In this section, we will discuss how to use Pabbly Connect to automate posting new products to Twitter from BigCommerce. This integration allows business owners to save time and streamline their social media marketing efforts.
Using Pabbly Connect, you can easily connect your BigCommerce store to your Twitter account without any coding skills. This automation ensures that every time a new product is added to your store, a tweet is automatically posted, keeping your followers informed about your latest offerings.
To start the automation process, first log in to your Pabbly Connect account. If you don’t have an account, you can sign up for free and receive 100 free tasks every month. Once logged in, navigate to the ‘All Apps’ section and select Pabbly Connect.
Click on the ‘Create Workflow’ button. You will be prompted to name your workflow. For this integration, name it ‘Automatically Post New Products to Twitter from BigCommerce’. Then, select the classic method to create your workflow.
- Log in to Pabbly Connect.
 - Navigate to ‘All Apps’ and select Pabbly Connect.
 - Click on ‘Create Workflow’ and name it accordingly.
After naming your workflow, click the ‘Create’ button. You will see two windows: the trigger window and the action window. The trigger window is where you will set up the event that starts the automation.
3. Setting Up the Trigger for New Products
In the trigger window, select BigCommerce as your trigger application. The event you want to choose is ‘New Product’. This means that whenever a new product is added to your BigCommerce store, it will trigger the automation.
Click on the ‘Connect’ button and then select ‘Add New Connection’. You will need to enter your BigCommerce API credentials, including the Client ID, Access Token, and Store Hash Key. This information can be found in your BigCommerce account under the API section.
- Select BigCommerce as the trigger application.
 - Choose ‘New Product’ as the trigger event.
 - Enter your API credentials from BigCommerce.
Once connected, click on the ‘Save and Send Test Request’ button to verify the connection. This will ensure that Pabbly Connect can successfully capture new product details from your BigCommerce store.
4. Adding the Action Step to Post on Twitter
After successfully setting up the trigger, you will need to add an action step to post the product information on Twitter. In the action window, select Twitter (now known as X) as your action application and choose ‘Create Tweet’ as the action event. using Pabbly Connect
Click on the ‘Connect’ button and select ‘Add New Connection’. You will need your Twitter API credentials, including the Client ID and Client Secret. This information can be obtained by creating a developer account on Twitter and setting up an application.
Select Twitter as the action application. Choose ‘Create Tweet’ as the action event. Enter your Twitter API credentials.
Once connected, you can customize the tweet message. You can map the product name and URL from the previous steps to create a dynamic tweet that includes the product details. Finally, click on the ‘Save and Send Test Request’ button to test the tweet creation.
5. Verifying the Integration Between BigCommerce and Twitter
To verify that the integration works correctly, go back to your BigCommerce store and add a new product. For example, you can create a new product called ‘Midnight Elegance Black Dress’ with all the necessary details.
After saving the new product, check your Twitter account. Refresh the page to see if a new tweet has been posted automatically. The tweet should contain the product name and a link to the product page on your BigCommerce store.
This confirms that your automation is functioning as intended. Now, every time you add a new product to your BigCommerce store, Pabbly Connect will ensure that a corresponding tweet is automatically posted, keeping your followers updated with your latest products.
In conclusion, using Pabbly Connect allows you to effortlessly automate the process of posting new products to Twitter from BigCommerce. This integration saves time and enhances your social media presence.
By following the steps outlined in this tutorial, you can set up this automation without any coding knowledge, making it accessible for all business owners looking to streamline their marketing efforts.
