Learn how to automatically post new products from WooCommerce to Pinterest using Pabbly Connect. Step-by-step tutorial with detailed instructions. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To automatically post new products to Pinterest from WooCommerce, we will use Pabbly Connect. First, open a new tab and go to the Pabbly Connect website by entering ‘Pabbly.com/connect’ in the search bar. This platform allows you to create automated workflows seamlessly.
Once on the Pabbly Connect homepage, you can either sign up for a new account or log in if you already have one. After signing in, you will land on the dashboard where you can manage your automation workflows. Click on the ‘Create Workflow’ button to begin setting up your integration.
After clicking the ‘Create Workflow’ button, you will need to select the new version of the workflow builder for a more efficient setup. Enter the workflow name, ‘Automatically Post New Products to Pinterest from WooCommerce,’ and select a folder to organize your workflow. Click the ‘Create’ button to proceed. using Pabbly Connect
- Choose a name that reflects the automation purpose.
- Select a folder to keep your workflows organized.
- Click on the ‘Create’ button to set up the workflow.
Now you will see the workflow builder interface. Here, toggle the button on to activate your workflow. The next step is to set up a trigger, which will start the automation process whenever a new product is created in WooCommerce.
3. Setting Up the Trigger for WooCommerce
In the workflow builder, click on the plus icon to add a trigger. Search for ‘WooCommerce’ and select it as your trigger app. Choose the event ‘New Order Created’ to ensure that the workflow is activated every time a new product is added to your WooCommerce store.
Next, click on the ‘Connect’ button. You will receive a webhook URL from Pabbly Connect, which acts as a bridge between your WooCommerce account and the automation platform. Copy this URL, as you will need to add it to your WooCommerce settings.
- Select ‘WooCommerce’ as the trigger app.
- Choose ‘New Order Created’ as the trigger event.
- Copy the webhook URL for use in WooCommerce settings.
After copying the URL, log in to your WordPress account and navigate to the WooCommerce settings. Under the ‘Advanced’ tab, find the ‘Webhooks’ option and paste the copied URL into the delivery URL field. This setup will ensure that every new product triggers a pin creation in Pinterest.
4. Creating a New Product in WooCommerce
Now that you have set up the trigger, it’s time to create a new product in WooCommerce. Go to the ‘Products’ section and click on ‘Add New Product.’ Here, you can fill in the product details such as name, description, and images.
For example, let’s create a product named ‘Summer Dress’. Enter a description, set the regular price, and upload a product image. After filling in all the necessary details, click on the ‘Publish’ button to make the product live. This action will trigger the webhook you set up earlier.
Go to the ‘Products’ section in WooCommerce. Click on ‘Add New Product’ to enter product details. Fill in the product name, description, and images before publishing.
Once the product is published, return to your Pabbly Connect dashboard. You should see a response indicating that the webhook has received the product details, confirming that the trigger is functioning correctly.
5. Creating a Pin in Pinterest Using Pabbly Connect
With the product created, the next step is to create a pin in Pinterest. In your workflow on Pabbly Connect, add an action step and select ‘Pinterest’ as the action app. Choose the event ‘Create a Pin’ to proceed with generating a new pin for the product.
Click on the ‘Connect’ button to link your Pinterest account. Ensure that you have your Pinterest account open in another tab to facilitate the connection. Once connected, you will need to specify the board where the pin will be posted, along with the image URL, title, and description that you mapped from the WooCommerce product data.
Select ‘Pinterest’ as the action app. Choose ‘Create a Pin’ as the action event. Map the product details such as title, description, and image URL.
Finally, click on the ‘Save and Send Test Request’ button to create the pin. Upon successful creation, you can check your Pinterest account to see the new pin reflecting the product details. This integration allows you to automatically post new products to Pinterest, enhancing your online visibility and driving traffic to your store.
In this tutorial, we explored how to use Pabbly Connect to automatically post new products from WooCommerce to Pinterest. By following the steps outlined, you can streamline your product promotion and enhance your online sales effortlessly. Automating this process not only saves time but also increases your reach and engagement with potential customers.
