Learn how to automatically post daily polls on Twitter using Pabbly Connect and an AI agent. Follow our step-by-step tutorial for seamless integration. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Accessing Pabbly Connect to Set Up Your Workflow
To automatically post daily polls on Twitter using Pabbly Connect, start by accessing the platform. Open a new tab and navigate to the Pabbly Connect website at www.Pabbly.com/connect. Once on the landing page, you will see options to sign in or sign up for free.
If you are a new user, sign up for a free account to get 100 free tasks every month. Existing users can directly sign in. After signing in, you will see the Pabbly apps window. Click on the ‘Access Now’ button next to Pabbly Connect to proceed to the dashboard.
Once you are in the Pabbly Connect dashboard, the next step is to create a workflow. Click on the button in the top right corner labeled ‘Create Workflow’. You will be prompted to name your workflow; enter a name that reflects its purpose, such as ‘AI Agent to Automatically Post Daily Polls on Twitter’.
- Select a folder to save your workflow from the dropdown menu.
- Click the ‘Create’ button to finalize your workflow setup.
This will create your workflow, which consists of a trigger and an action. The trigger will initiate the process, while the action will execute the task. In this case, the trigger will be set to run daily at a specified time.
In the workflow setup, the first step is to configure the trigger. Select ‘Schedule by Pabbly’ as your trigger application. This allows you to schedule your workflow to run daily. Set the trigger event to ‘Schedule Workflow’ and specify how often you want it to run. Choose ‘Every Day’ and set the time to 10:30 AM according to your account’s time zone.
- Ensure that you save the settings after selecting the time.
- This setup will ensure that the workflow triggers daily at the specified time.
After saving the trigger settings, you are now ready to set up the action that generates poll questions using an AI agent. This is where Pabbly Connect truly shines by automating the entire process.
4. Integrating OpenAI as the AI Agent
The next step in your workflow is to integrate an AI agent that will generate the poll questions. For this, you will select OpenAI as your action application. Choose ‘ChatGPT’ as the action event and click on the ‘Connect’ button to establish a connection.
To connect OpenAI to Pabbly Connect, you will need an API token. Generate a new token in your OpenAI account and paste it into the provided field in Pabbly Connect. After successfully connecting, select the AI model you want to use, such as GPT-4 Mini, and specify a prompt for generating the poll questions.
5. Creating the Poll on Twitter Using Pabbly Connect
After the AI agent generates the poll question and options, the final step is to create the poll on Twitter. For this, select ‘X (formerly Twitter)’ as your action application. Set the action event to ‘Create Poll Tweet’ and click on the ‘Connect’ button.
You will need to authorize the connection by providing your client ID and client secret from your Twitter developer account. Once authorized, map the generated poll question and options from the previous steps to the respective fields in the Twitter action setup.
Set the poll duration to 1440 minutes for a full day of activity. After filling in all required details, click on the ‘Save and Send Test Request’ button to verify the setup. Upon successful completion, your poll will automatically post on Twitter at the specified time every day, thanks to Pabbly Connect and your AI agent.
Using Pabbly Connect, you can seamlessly automate the process of posting daily polls on Twitter with the help of an AI agent. This integration not only saves time but also enhances customer engagement by providing fresh content daily.
