Learn how to automatically create pins in Pinterest from Facebook posts using Pabbly Connect. This detailed tutorial covers every step of the integration process. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
1. Accessing Pabbly Connect for Facebook and Pinterest Integration
To automatically create pins in Pinterest from Facebook posts, you need to access Pabbly Connect. First, open your browser and navigate to the Pabbly website by typing ‘Pabbly.com’. From there, go to the products section and select Pabbly Connect.
If you are a first-time user, click on ‘Sign Up for Free’ to create an account. If you already have an account, simply click on ‘Sign In’. After logging in, access Pabbly Connect to start setting up your integration.
Once you are in Pabbly Connect, you need to create a new workflow. Click on the plus sign to create a workflow and name it something descriptive like ‘Facebook and Pinterest Integration’. This name can be customized to suit your preference.
In Pabbly Connect, workflows operate on a trigger-action basis. The trigger will be a new post created on Facebook, and the action will be creating a pin on Pinterest. Make sure to set this up correctly for the integration to work seamlessly.
- Click on the ‘+’ icon to create a new workflow.
- Name your workflow as per your requirement.
- Configure the trigger and action settings accordingly.
After setting up the workflow, you can proceed with the integration process between Facebook and Pinterest using Pabbly Connect.
3. Connecting Facebook to Pabbly Connect
The next step in your integration process is to connect Facebook to Pabbly Connect. Open the trigger window and select Facebook Pages as the application. For the trigger event, choose ‘New Post’. Click on ‘Connect’ and then ‘Add New Connection’.
You will be prompted to log into your Facebook account if you aren’t already logged in. Once authorized, select the Facebook page from which you want to capture posts. After selecting the page, you need to create a new post on Facebook to test the connection.
- Select Facebook Pages as the application in Pabbly Connect.
- Choose ‘New Post’ as the trigger event.
- Authorize your Facebook account to connect.
After successfully connecting, you can move forward to capture the details of the Facebook post for the next step in your workflow.
4. Creating a Pin in Pinterest via Pabbly Connect
After capturing the Facebook post details, the next step is to create a pin in Pinterest using Pabbly Connect. Open the action window and select Pinterest as the application. Choose ‘Create Pin’ as the action event, then click on ‘Connect’ to link your Pinterest account.
Once connected, you will need to select the board where the pin will be added. Map the details from the Facebook post, including the image URL and the caption, to create the pin accurately. Ensure you fill in all required fields, such as the title and description, to complete the pin setup.
Select Pinterest as the application in the action window. Choose ‘Create Pin’ as the action event. Map the Facebook post details to the pin fields.
After completing these steps, you can save and test the workflow to ensure everything is functioning as expected.
5. Testing the Integration Between Facebook and Pinterest
To finalize your integration, it’s crucial to test it to ensure that new Facebook posts are automatically creating pins in Pinterest via Pabbly Connect. Go back to your Facebook page and create a new post. After posting, check your Pinterest account to see if the new pin appears.
Keep in mind that the trigger is polling-based, so it may take a few minutes for the new pin to show up in Pinterest. If it doesn’t appear immediately, wait for about 15-20 minutes and refresh your Pinterest account.
Create a new post on Facebook to initiate the test. Check your Pinterest account for the newly created pin. Refresh Pinterest after waiting for a few minutes.
Once confirmed, your integration is complete, allowing for seamless automation of creating pins from Facebook posts using Pabbly Connect.
In conclusion, using Pabbly Connect allows you to automate the process of creating pins in Pinterest from Facebook posts effortlessly. By following the detailed steps outlined in this tutorial, you can set up this integration in no time. Automate your social media presence effectively with Pabbly Connect.
