Learn how to create a Toggl Track task automatically from a GitHub issue using Pabbly Connect. Step-by-step guide with detailed instructions. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To create Toggl Track tasks from GitHub issues, start by accessing Pabbly Connect. This integration platform allows you to connect various applications effortlessly without coding skills.
Visit the Pabbly Connect homepage by typing the URL in your browser. You will see options to sign in or sign up for free. New users can create an account, which includes 100 free tasks per month to explore the platform. Existing users can click on ‘Sign In’ to access their dashboards.
Once you are signed into Pabbly Connect, the dashboard will display all your workflows. To create a new workflow, click on the ‘Create Workflow’ option. A dialog box will appear, prompting you to name your workflow.
- Name your workflow (e.g., ‘Create Toggl Task from GitHub Issue’).
- Select a folder to save your workflow (e.g., GitHub and Toggl Automations).
After creating the workflow, you will see two windows: one for the trigger and another for the action. The trigger will be GitHub, and the action will be Toggl Track.
3. Setting Up the Trigger with GitHub
In this step, you will configure the trigger using GitHub in Pabbly Connect. Select GitHub as the trigger application and choose the trigger event as ‘Issues’. This means the workflow will trigger whenever a new issue is created in GitHub.
Click on ‘Connect’ and then select ‘Add New Connection’ to build a connection with your GitHub account. Authorize Pabbly Connect to access your GitHub account by clicking on ‘Authorize’. Once authorized, select the repository where you will create issues.
- Click on ‘Save and Send Test Request’.
- Create a new issue in GitHub to test the connection.
- Check the response in Pabbly Connect to confirm successful integration.
After submitting a test issue, you should see the details captured in Pabbly Connect, confirming that the connection is successful.
4. Configuring the Action to Create a Task in Toggl Track
Now that the trigger is set up, it’s time to configure the action. Select Toggl Track as the action application in Pabbly Connect. Choose the action event as ‘Create Task’. This will create a new task in Toggl Track whenever a new issue is raised in GitHub.
Click on ‘Connect’ and select your existing connection with Toggl Track. If you haven’t connected before, create a new connection by entering your Toggl Track login credentials. Once connected, you will need to fill in the task details.
Select the workspace where you want to create the task. Choose the project where the task will be added. Map the title of the task to the title of the GitHub issue.
After filling in the required fields, click on ‘Save and Send Test Request’ to create the task in Toggl Track. You should see a response confirming that the task has been created successfully.
With the workflow configured, it’s time to test the integration between GitHub and Toggl Track using Pabbly Connect. Create a new issue in GitHub to check if it automatically creates a task in Toggl Track.
After submitting a new issue with a title and description, return to Toggl Track and refresh the page. You should see the new task created based on the GitHub issue title. This confirms that the integration is functioning correctly and automatically creating tasks in Toggl Track.
In summary, the integration allows you to streamline your workflow by automatically creating tasks in Toggl Track from GitHub issues. The use of Pabbly Connect simplifies this process without the need for coding or technical skills.
Using Pabbly Connect, you can easily automate the creation of Toggl Track tasks from GitHub issues. This integration enhances productivity by ensuring that tasks are created automatically, allowing for efficient project management.
