Learn how to automate student enrollment in Thrive Cart Learn using P Connect and Paper Form submissions. Follow our step-by-step guide for seamless integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation. with Pabbly Connect.
1. Introduction to P Connect and Thrive Integration
P Connect is a powerful tool that automates workflows between applications like Thrive, PAB, Java, and others. In this tutorial, we will focus on how to enroll students in Thrive Cart Learn using Paper Form submissions. This integration simplifies the enrollment process for course creators.
As a digital creator, managing student enrollments can be challenging. By utilizing P Connect, you can streamline this process without any coding skills. This tutorial will guide you through each step of setting up this automation.
2. Setting Up Your P Connect Account
To begin, you need to create a P Connect account. Visit the P Connect homepage and either sign in or sign up for a free account. After signing in, navigate to the dashboard where you can manage your workflows. using Pabbly Connect
Here’s how to set up your P Connect account:
- Go to the P Connect homepage.
- Click on ‘Sign Up for Free’ if you are a new user.
- Log into your account if you are an existing user.
After logging in, you will see the option to create a new workflow. Click on the ‘Create Workflow’ button to start the automation process.
3. Creating the Workflow for Student Enrollment
In this section, we will create a workflow to enroll students in Thrive Cart Learn upon Paper Form submission. Start by naming your workflow, for example, ‘Enroll Thrive Cart Learn User from Paper Form Submission’. Select the appropriate folder for organization. using Pabbly Connect
Next, we will define the trigger and action for the workflow. The trigger will be a new submission from Paper Form, and the action will be adding a user to Thrive Cart Learn. This is crucial for the automation to function correctly.
- Select ‘Paper Form’ as the trigger application.
- Choose ‘New Submission’ as the trigger event.
- Set ‘Thrive Cart Learn’ as the action application.
After selecting these options, you will receive a webhook URL. This URL will be used to connect your Paper Form to P Connect.
4. Connecting Paper Form to P Connect
To establish a connection between Paper Form and P Connect, copy the webhook URL provided by P Connect. Now, log into your Paper Form account and navigate to the form you want to connect. using Pabbly Connect
Here’s how to integrate Paper Form with P Connect:
Edit your registration form in Paper Form. Go to the ‘Integrations’ section and select ‘Webhooks’. Paste the webhook URL and set the trigger to ‘New Submission’.
Once the webhook is saved, perform a test submission to ensure that the connection is working. The response should appear in P Connect, confirming that the integration is successful.
5. Enrolling Students in Thrive Cart Learn
After successfully connecting Paper Form to P Connect, the next step is to enroll students in Thrive Cart Learn. Select ‘Thrive Cart Learn’ as the action application and choose ‘Create New Student’ as the event. using Pabbly Connect
To complete the enrollment process, you need to enter the student’s details. This includes their email, course ID, and name. Map these fields dynamically from the previous response received from Paper Form.
Map the email address of the student from the response. Provide the course ID for the Java course. Include the student’s full name by mapping the first and last name.
Once you have filled in all the necessary fields, click on ‘Save and Send Test Request’. This action will create a new student in Thrive Cart Learn, confirming that the integration is functioning as expected.
This tutorial demonstrated how to automate student enrollment in Thrive Cart Learn using P Connect and Paper Form submissions. By following these steps, you can streamline your enrollment process and ensure that each new student is added automatically.
Utilizing P Connect for this integration allows you to manage your courses efficiently and enhance your digital creation business.
