Learn how to automate student enrollment in Graphy upon successful Razorpay payment using Pabbly Connect. Follow our step-by-step guide for seamless integration. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To automate student enrollment in Graphy after a successful payment through Razorpay, you first need to set up Pabbly Connect. Access Pabbly Connect by logging into your account and navigating to the dashboard.
Once you are on the dashboard, you can create a new workflow. This workflow will handle the integration between Razorpay and Graphy. Select the option to create a new workflow and give it a relevant name, such as ‘Graphy Enrollment on Razorpay Payment’.
2. Configuring Razorpay Trigger in Pabbly Connect
The next step is to configure Razorpay as the trigger application in your Pabbly Connect workflow. This requires you to select Razorpay from the list of applications.
- Choose the trigger event as ‘Payment Successful’.
- Connect your Razorpay account by providing the API key and secret.
- Test the connection to ensure it’s working correctly.
After configuring the trigger, you will be able to capture payment details automatically whenever a student makes a successful payment through Razorpay.
3. Setting Graphy as the Action in Pabbly Connect
After configuring the Razorpay trigger, the next step is to set Graphy as the action application in your Pabbly Connect workflow. Select Graphy from the application list.
Choose the action event as ‘Enroll Student’. You will be prompted to connect your Graphy account. Provide the necessary credentials to authenticate the connection.
- Map the fields from Razorpay to Graphy, such as student name, email, and course details.
- Ensure all required fields in Graphy are filled correctly.
Once the fields are mapped, test the action to confirm that the student enrollment is processed successfully in Graphy.
4. Finalizing the Integration in Pabbly Connect
With Razorpay and Graphy configured, it’s time to finalize your Pabbly Connect integration. Review the workflow to ensure all settings are correct and that the mapping of fields is accurate.
Once you are satisfied, turn on the workflow. This will activate the automation, allowing students to be enrolled in Graphy automatically upon successful payment through Razorpay.
Monitor the workflow for any errors or issues. Make adjustments as necessary to ensure smooth operation.
After finalizing, your integration will work seamlessly, enhancing the enrollment process for students.
5. Conclusion: Automate Enrollment with Pabbly Connect
In conclusion, using Pabbly Connect to integrate Razorpay and Graphy allows for automatic student enrollment upon successful payment. This automation not only saves time but also improves the efficiency of the enrollment process.
By following the steps outlined in this tutorial, you can set up a reliable workflow that enhances your educational offerings. Start automating your processes today with Pabbly Connect!
