Learn how to automate product review request emails after Stripe payments using Pabbly Connect. Follow our step-by-step tutorial to streamline your email processes. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
To begin automating product review request emails after a Stripe payment, you first need to access Pabbly Connect. Open a new tab in your browser and navigate to the Pabbly Connect landing page by entering ‘Pabbly.com/connect’.
Once you’re on the Pabbly Connect page, you will see two options: ‘Sign In’ and ‘Sign Up for Free’. If you are a new user, click on ‘Sign Up for Free’ to create your account. Existing users should click on ‘Sign In’ to access their dashboard. After signing in, select Pabbly Connect from the list of applications available to proceed with your automation setup.
After accessing Pabbly Connect, the next step is to create a workflow. Click on the ‘Create Workflow’ button. You will be prompted to choose between the new workflow builder and the classic one. Opt for the new one for a modern interface.
Now, name your workflow as ‘Send Automated Product Review Request Emails After Stripe Payment’ and choose a folder to save it in. After naming it, click on the ‘Create’ button to open the workflow window, where you can set up triggers and actions.
- Click on ‘Create Workflow’.
- Select the new workflow builder.
- Choose a folder for your workflow.
With your workflow created, you are now ready to set up the trigger for Stripe payments.
3. Setting Up the Trigger with Stripe
Your next action is to set up the trigger application, which in this case is Stripe. In the workflow window, search for and select ‘Stripe’ as your trigger application. For the trigger event, choose ‘New Charge’ and click on ‘Connect’. using Pabbly Connect
Pabbly Connect will provide a webhook URL that you need to copy. Then, log into your Stripe account, navigate to the ‘Developers’ section, and select ‘Webhooks’. Click on ‘Add Endpoint’ and paste the copied URL into the designated field. Choose ‘Charge Succeeded’ from the events dropdown and click on ‘Add Events’ to finalize the setup.
- Select ‘Stripe’ as the trigger application.
- Choose ‘New Charge’ as the trigger event.
- Add this URL to your Stripe webhooks.
After successfully adding the webhook, Pabbly Connect will wait for a webhook response, which you can test by making a dummy payment through Stripe.
4. Sending Automated Emails with Gmail
Once the Stripe trigger is set up, the next step is to configure the action application, which is Gmail. Click on the ‘Add New Action’ button and select ‘Gmail’ as the action application. For the action event, choose ‘Send Email’ and click on ‘Connect’. using Pabbly Connect
You will need to grant Pabbly Connect access to your Gmail account. After connecting, you will be prompted to fill in the recipient’s email address, which you can map from the Stripe trigger response. Additionally, enter the sender’s name, subject line, and email content. Use HTML format for more engaging emails.
Select ‘Gmail’ as the action application. Choose ‘Send Email’ as the action event. Map the recipient’s email from the Stripe response. Fill in the email content and subject line.
After filling in all necessary details, click on ‘Save and Send Test Request’ to see if the email is sent successfully. Check your Gmail inbox to confirm receipt.
5. Testing the Integration
With the workflow fully set up, it’s crucial to test the integration to ensure everything works seamlessly. Perform a test transaction through Stripe using the payment link you created. After completing the payment, Pabbly Connect should capture the response, and you should see all relevant details in your workflow. using Pabbly Connect
Check your Gmail inbox for the automated product review request email. The email should be personalized with the customer’s name and contain a link for leaving a review. This confirms that your automation is functioning correctly, sending follow-up emails promptly after a successful payment.
Whenever a new payment is made through Stripe, this workflow will automatically trigger, sending personalized emails to customers. This not only enhances customer engagement but also boosts social proof for your products.
In conclusion, using Pabbly Connect to automate product review request emails after Stripe payments streamlines your email processes and enhances customer interaction. By following the steps outlined in this tutorial, you can easily set up and manage your automated workflows.
