Learn how to create Pinterest pins automatically from WooCommerce products using Pabbly Connect. Follow our step-by-step tutorial for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To create Pinterest pins automatically from WooCommerce products, you’ll first need to access Pabbly Connect. This powerful integration tool enables seamless connections between your WooCommerce store and Pinterest. If you don’t have an account yet, you can create a free one in just a few minutes.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can start your automation process by clicking on the blue ‘Create Workflow’ button. This initiates the connection setup for your WooCommerce and Pinterest integration.
In this step, you will create a new workflow to automate the process of posting WooCommerce products to Pinterest. After clicking on ‘Create Workflow,’ give your workflow a name like ‘Share WooCommerce Products Automatically to Pinterest.’ Select the folder where you want to save this workflow and click on ‘Create’. using Pabbly Connect
Next, you will see two boxes representing the trigger and action. The trigger is what starts the automation, and the action is what happens as a result. For this integration, select WooCommerce as the trigger app and choose the ‘New Product Created’ event. This means that every time a new product is added to WooCommerce, it will trigger an action in Pinterest.
3. Connect WooCommerce with Pabbly Connect
To connect WooCommerce with Pabbly Connect, you will need to set up a webhook. Copy the webhook URL provided by Pabbly Connect and go to your WooCommerce dashboard. In the settings, navigate to the ‘Advanced’ section, then select ‘Webhooks’. Here, click on ‘Add Webhook’.
- Provide a name for the webhook, such as ‘Connection with Pabbly Connect’.
- Set the status to ‘Active’.
- For the topic, select ‘Product Created’.
- Paste the copied webhook URL into the ‘Delivery URL’ field.
After saving the webhook, Pabbly Connect will start waiting for a response from WooCommerce. This establishes a connection between the two platforms, allowing Pabbly Connect to capture product details whenever a new product is created.
4. Test the Connection by Adding a New Product
Now that you have connected WooCommerce to Pabbly Connect, it’s time to test the integration. Go back to your WooCommerce dashboard and add a new product. Fill in the product details, such as the name, description, price, and image. Once you publish the product, Pabbly Connect will capture the product details as a webhook response.
After publishing the product, check the Pabbly Connect dashboard to see if the product information has been received. You should see all relevant details like product name, description, and image URL. This confirms that the connection is working properly and that Pabbly Connect is capturing the necessary data for the next step.
5. Create a Pinterest Pin Using Pabbly Connect
Now that the connection is established and tested, you can proceed to create a Pinterest pin using the data captured by Pabbly Connect. In the action step, select Pinterest as the application and choose the ‘Create Pin’ action. Click on ‘Connect’ to link your Pinterest account with Pabbly Connect.
- Choose the board where you want to post the pin.
- Map the image URL and product title from the previous step to the respective fields.
- Use the ‘Text Formatter’ feature in Pabbly Connect to clean up the product description by removing any HTML tags.
After mapping all necessary fields, save the settings and send a test request. If successful, check your Pinterest board to see the new pin created from your WooCommerce product. This automation will save you time and effort by posting new products to Pinterest automatically.
By using Pabbly Connect, you can easily automate the creation of Pinterest pins from WooCommerce products automatically. This integration not only saves time but also enhances your marketing efforts by ensuring your products are always represented on Pinterest. Start automating your workflow today for better efficiency!
