Learn how to automate LinkedIn article curation and posting using Pabbly Connect with AI agents. Follow this detailed tutorial for seamless integration. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To start automating LinkedIn article curation, first access Pabbly Connect by typing ‘Pabbly.com/connect’ in your browser. This will direct you to the landing page where you can sign in or sign up for free.
If you are a new user, click on the ‘Sign up for free’ button to create an account. After signing up, you’ll receive 100 free tasks each month to explore Pabbly Connect and test various automations. Existing users can simply log in to their accounts.
Once logged into Pabbly Connect, navigate to the dashboard and click on the ‘Create Workflow’ button. This will prompt you to name your workflow, such as ‘Use AI Agents for Automated LinkedIn Article Creation and Posting’.
After naming your workflow, select an appropriate folder for organization. For this example, choose the folder named ‘AI Automations’ and click on ‘Create’. Your new workflow will now be ready for configuration.
3. Setting Up the Trigger with RSS by Pabbly
In the newly created workflow, you need to set up the trigger by selecting ‘RSS by Pabbly’. Choose the trigger event as ‘New Item in Feed’. This action will allow Pabbly Connect to monitor your RSS feed for new articles.
Next, enter the feed URL from which you want to collect articles. For example, you can use a business news RSS feed. After pasting the URL, select the default filter and click on ‘Save and Send Test Request’. This step will fetch the latest article details from the feed.
  • Select ‘RSS by Pabbly’ as your trigger application.
  • Choose ‘New Item in Feed’ as the trigger event.
  • Paste your RSS feed URL and click ‘Save and Send Test Request’.
Once the test request is successful, you’ll see the latest article’s title and description, which will be used for curation.
4. Curating the Article with OpenAI
For the next step, select ‘OpenAI’ as the action application in Pabbly Connect. The action event should be set to ‘ChatGPT’, which will allow you to curate the article. Click on ‘Connect’ to establish a connection between OpenAI and Pabbly Connect.
If you don’t have an existing connection, you will need to create one. Log into your OpenAI account and obtain your API token. Once you have the token, paste it into Pabbly Connect and click ‘Save’.
  • Select ‘OpenAI’ as the action application.
  • Choose ‘ChatGPT’ as the action event and connect your OpenAI account.
  • Insert your API token and click ‘Save’.
With the connection established, set the model to ‘ChatGPT-4’ and create a prompt that instructs OpenAI on how to curate the article for LinkedIn.
5. Posting the Curated Article to LinkedIn
After curating the article, the final step is to post it on LinkedIn. In Pabbly Connect, add a new action step and select ‘LinkedIn’ as the application. Choose the action event ‘Share a Simple Text’.
Connect your LinkedIn account by selecting your existing connection. You will need to set the content of the post with the curated article generated by OpenAI. Click on ‘Save and Send Test Request’ to publish the post on your LinkedIn profile.
Once the test is successful, you can check your LinkedIn profile to see the newly posted article. This process demonstrates how Pabbly Connect automates the workflow from RSS feed collection to LinkedIn posting seamlessly.
Using Pabbly Connect, you can automate LinkedIn article curation and posting efficiently. By integrating RSS feeds and OpenAI, you can streamline your content sharing process and enhance engagement on your LinkedIn profile.
