Learn how to automate Kit subscriber creation from Zoho Forms submissions using Pabbly Connect. Step-by-step tutorial for seamless integration. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To automate the creation of Kit subscribers from Zoho Forms submissions, the first step is to access Pabbly Connect. Open your browser and search for Pabbly Connect by visiting Pabbly.com/connect. Once there, you have two options: sign in if you are an existing user or sign up for free if you are new.
After signing in, you will see various tools offered by Pabbly. Click on the ‘Access Now’ button under Pabbly Connect to enter your dashboard. From here, you can start creating your workflow to link Zoho Forms with Kit, ensuring seamless subscriber management.
In your Pabbly Connect dashboard, click on the ‘Create Workflow’ button. You will need to name your workflow, for instance, ‘Create Kit Subscriber on Zoho Forms Submission’ and choose a folder to save it in. This helps keep your automations organized. Click ‘Create’ to open the workflow window.
- Select Zoho Forms as the trigger application.
- Choose the trigger event as ‘New Form Submission’.
- Copy the provided Webhook URL.
This step is critical as it establishes the connection between Zoho Forms and Pabbly Connect. The Webhook URL will be used to send data from Zoho Forms to Pabbly Connect whenever a new submission occurs.
3. Setting Up Zoho Forms for Integration
Next, log into your Zoho Forms account and locate the form you want to integrate. Click on the ‘Edit’ option for that form. Navigate to the ‘Integrations’ section and select ‘Webhooks’. Here, you will enable the webhook status and paste the Webhook URL you copied earlier from Pabbly Connect.
- Set the content type to ‘application/json’.
- Choose ‘None’ for the authorization type.
- Click ‘Save’ to finalize the webhook setup.
After saving, your Zoho Forms is now connected to Pabbly Connect. This means that every new submission will trigger the workflow you created, sending data to Pabbly Connect for further processing.
To ensure everything is working correctly, perform a test submission on your Zoho Form. Fill out the form with sample data and click ‘Submit’. You should see a confirmation message indicating that your submission was received.
Return to your Pabbly Connect dashboard. You will notice that the workflow is now waiting for a webhook response, indicating that it has captured the test submission data. This confirms that the integration between Zoho Forms and Pabbly Connect is functioning properly.
5. Creating a Kit Subscriber Using Pabbly Connect
Now, you can set up the action to create a Kit subscriber. In your workflow, select Kit as the action application and choose ‘Add Subscriber’ as the action event. If you haven’t connected your Kit account yet, click on ‘Add New Connection’ and provide your API key and secret from your Kit account settings.
Map the fields from your Zoho Forms submission to the corresponding fields in Kit. This includes first name, last name, email, and any other relevant details. By mapping these fields, you ensure that the subscriber information is correctly populated in Kit based on the data received from Zoho Forms.
Once everything is mapped, click on ‘Send Test Request’. You should receive a confirmation that the subscriber has been successfully added to your Kit account. This finalizes the integration, allowing you to create Kit subscribers automatically with every new Zoho Forms submission through Pabbly Connect.
By following this tutorial, you have successfully set up an automation that creates Kit subscribers from Zoho Forms submissions using Pabbly Connect. This integration saves time and enhances your email marketing efforts by ensuring that all new leads are captured seamlessly. Automate your workflows today with Pabbly Connect for efficient management of your subscriber lists.
