Learn how to automatically send Instamojo order confirmations on WhatsApp using Pabbly Connect. Step-by-step guide for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Setting Up Pabbly Connect for Instamojo and WhatsApp Integration
To automate the sending of order confirmations from Instamojo to WhatsApp, you first need to access Pabbly Connect. This platform facilitates the integration between various applications, allowing for seamless automation. Start by visiting Pabbly Connect and signing up for an account if you haven’t already.
Once logged in, navigate to the dashboard, where you will find a blue button labeled ‘Create Workflow’. Click on it to initiate the setup process for your automation. Name your workflow something descriptive, such as ‘Send Instamojo Order Confirmation on WhatsApp’. After naming your workflow, click on ‘Create’ to proceed.
2. Selecting Trigger Event in Pabbly Connect
In this step, you will set up the trigger event that will initiate the automation. Choose Pabbly Connect as your integration platform and select Instamojo as the application. The trigger event you need to select is ‘New Sale’. This event will activate every time a new sale is made through your Instamojo account.
- Select Instamojo as the application.
- Choose ‘New Sale’ as the trigger event.
After setting up the trigger, you will need to create a new payment link in your Instamojo account. This link will be used to test the automation. Ensure that you enable the webhook option and paste the copied URL from Pabbly Connect into the designated field. This setup allows Pabbly to capture the sale data automatically.
3. Testing the Connection with Instamojo
Now that you have set up the webhook, it’s time to test the connection. Go back to your Instamojo account and create a test payment using the link you just generated. Fill in the necessary details like name, email, and phone number. This step is crucial as it allows Pabbly Connect to receive the payment data and confirm that the integration is working correctly.
Once you complete the payment, return to Pabbly Connect. You should see a successful response indicating that the sale data has been captured. This response will include details such as payment ID, amount, and customer information. If the data appears correctly, the connection is established successfully.
4. Sending Order Confirmation via WhatsApp
The final step involves sending the order confirmation message through WhatsApp using the Interact application. In Pabbly Connect, add a new action step and select Interact as the application. Choose the action event that corresponds to sending a WhatsApp message.
- Select Interact as the application.
- Choose ‘Send WhatsApp Message’ as the action event.
- Map the phone number and message template fields accordingly.
Ensure that you have created a WhatsApp message template in Interact prior to this step. You will need to provide the template code and any dynamic variables that should change based on the order details. After mapping these fields, save and send a test request to verify that the message is sent correctly to the customer’s WhatsApp.
By following these steps, you can effectively automate the sending of Instamojo order confirmations on WhatsApp using Pabbly Connect. This integration not only saves time but also enhances customer communication. With Pabbly Connect, you can streamline your business processes and focus on growth.
